03-10-2019 13:04
03-10-2019 13:04
Hi
My Versa screen is not responsive to swipe and touch.
I've restarted it using the buttons, but it hasn't made a difference. It's fully charged too and syncs with my phone ok. I've even changed the clock face to see if that's made a difference ...but no, still unresponsive.
Any other suggestions??
03-10-2019 13:51
03-10-2019 13:51
Hi, contact Customer Support, seems a hardware issue. Good luck!!
Best Answer03-10-2019 15:32
03-10-2019 15:32
@Mandy_Moo .. have you tried using the button to switch to the next screen and tap any of the apps from there? It probably won't change the outcome, but I am curious if it is the first screen that is causing issue or it is something more. It may unjam your screen - stranger things have happened 🙂
Elena | Pennsylvania
