05-02-2020 21:19
05-02-2020 21:19
My Versa battery was at 53% when I started my run. Was working fine for 20 minutes. About 10 minutes later, completely black screen. Got home and put on charger for over 2 hours...nothing. Tried to sync, but found there is a software update. Tried reset by holding all 3 buttons...nothing. What to do?
05-02-2020 23:44
05-02-2020 23:44
Mine too and it was near 50% charge when it died.
Is it broken had it a few years?
05-02-2020 23:47
05-02-2020 23:47
I have the same issue. Just that in my case I was doing pretty good and I always wait for the battery to get almost drain to put it to charge so I do not damage the battery. But this time, it turned off like it usually does but what it’s not normal its that it won’t turn on again. I spent more than a day trying to make it turn on but it won’t. so I stop trying for a day. Now that I checked it does light up the screen but it’s all black. No logo no functions not nothing . Just the black screen with its backlight. I try resetting it several times holding up the left bottom and the inferior right bottom and it won’t show the logo. then tried with the 3 of them and it stills the same. It was perfectly normal and now it doesn’t work? This is a big no!
