04-21-2021 12:31
04-21-2021 12:31
Fitbit versa working fine. Woke up to blank screen. Versa has counted steps all day as I can see on device. Has been vibrating, but can’t see anything on screen. Have tried reset and it doesn’t. Is fully charged? Any ideas welcome 🙏🏼
04-21-2021 21:50
04-21-2021 21:50
Is the watch syncing with the Fitbit App despite the blank screen?
You can check by clicking on your profile photo [top left] in the Fitbit App and see against device when last synced.
Try charging it, it should come on. If you can sync it will tell you the charge level in the Fitbit App.
If that works seems like a screen fault.
If its flat or not syncing or not charging have a look at the suggestion posted here
For further help contact Fitbit Support directly. They may be able to help you.
Best Answer04-21-2021 22:57
04-21-2021 22:57
Best Answer04-21-2021 23:05
04-21-2021 23:05
Hi Diane,
Thanks for the feedback, shame the screen is broken.
You can/should edit your last post [use the ...] because it's advisable to remove all your private information.
