10-21-2021
06:06
07:48
10-21-2021
06:06
07:48
My versa screen went black. It is still synced with my phone and can track my steps and sleep. However I can't see anything on my fitbit. I have held all 3 buttons for 12+ seconds and charged ect. This has been going on for 8 days. Any suggestions to fix this? Thanks
10-21-2021 07:52 - edited 11-02-2023 03:22
Hi there, @Hlulloff @Dhanyavinay. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit smartwatches before reaching out.
Since the restart you tried didn't work, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
@Dhanyavinay In answer to your question, please know when a Fitbit device is deemed defective we review eligibility using the one year warranty option.
Nevertheless, keep in mind that our products are indeed designed and made to last (this goes for each product component) though, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our warranty policy is set into providing as much coverage as we can. For our full warranty terms and conditions, see our Return Policy and Warranty.
Hope that helps.
Best Answer10-21-2021 07:39
10-21-2021 07:39
Even I am facing exactly same issue. Perhaps if screen is broken inside,do we have replacement support? I do see my device is perfectly fine as it syncs with my mobile app.But no display can be seen.Not even clock face
Best Answer10-21-2021 07:52 - edited 11-02-2023 03:22
Hope that helps.
