07-28-2021
08:42
09:52
07-28-2021
08:42
09:52
My Versa started to not sync, then was not keeping the correct time. I tried resetting it using the two button way. No luck. After 3 days of trying, I did a factory reset. Now the versa will not turn back on. I also tried to hold down all the buttons for over 3 minutes several times. No luck, the screen never shows the Fitbit logo. It stays black.
07-28-2021 09:52
07-28-2021 09:52
Hi there, @JKC18. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from.
It seems like the Factory Reset might have drained your Versa's battery. With that said, please try the following steps:
If you manage to turn on your watch's screen, please follow the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
07-28-2021 19:19
07-28-2021 19:19
The screen won't turn on at all, even after it has been fully charged (with a wall charger that turns off after power is no longer being drawn from it).
07-29-2021 04:14
07-29-2021 07:05 - edited 09-15-2023 05:54
@JKC18 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
