01-23-2019 22:39
01-23-2019 22:39
My Fitbit has been working perfectly since I bought it and now all of a sudden the screen went out. Yet the app is still showing that it is working. I read the post about holding all 3 buttons and all of that but nothing is working. I can’t function without my Fitbit so Please help!!
Best Answer01-24-2019 06:33
01-24-2019 06:33
Hi, when even a factory rest does not work, as you did by pressing all three buttons together (did you wait untill you felt a strong vibration and then released only the right lower button?), I would contact Customer Support, good luck!
10:47
08:11
01-25-2019
10:47
08:11
Welcome to the Community @jarla347 and @SunsetRunner thanks for the input.
I appreciate all the efforts in trying to fix this display issue. Upon checking with our support team, I was told that you followed our friend's recommendation and contacted them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else. ![]()
