12-10-2018
11:44
17:57
EdsonFitbit
12-10-2018
11:44
17:57
EdsonFitbit
I bought a versa a couple of weeks ago and love it but my samsung phone battery is awfull, I have seen a lot of posts regarding this but still no solution. Please help.
Moderator edit: added label
12-10-2018 12:53
12-10-2018 12:53
Hi, in order to try to help you the best I/we can, can you be more specific about your problem??
12-11-2018 00:00
12-11-2018 00:00
My phone battery just runs down so quickly and has only done so since I have been using the versa, I never had a problem with the HR2. I have checked all my settings and I am on "All day sinc" but other than that everything is good. I have seen that fitbit did a update to cure the problem but I don't think it had worked. I only bought the versa three weeks ago so all systems are up to date.
12-11-2018 06:56
12-11-2018 06:56
@Ginge29 Welcome to our Fitbit Community! Seems odd that your phone's battery started to drain fast. I would like to know a couple of details also: Is your Versa's battery draining quickly as well? Do you have the GPS or Bluetooth on your phone all the time enabled?
@SunsetRunner Thank you for your contribution in this thread!
See you both later!
12-13-2018 00:32
12-13-2018 00:32
12-13-2018 04:59 - edited 12-13-2018 05:01
Hi, Iwould advice you to switch off the "All day sync" setting cause that's draining also the battery. Do I understand you well that you have the display of your watch for a certain period of time set to "always on"? If yes, than this is the major issue of your battery problem. Good luck.
12-13-2018 23:37
12-13-2018 23:37
12-15-2018 07:49
12-15-2018 07:49
@Ginge29 I want to follow up on this and would like to know if your battery had improvement after following @SunsetRunner's tips.
Looking forward to your response!
