02-26-2019
15:02
04:16
HeydyF
02-26-2019
15:02
04:16
HeydyF
Why does my Versa battery only hold a charge for 2 1/2 days when it is suppose to hold a charge for 4 days?
02-27-2019 04:22
02-27-2019 04:22
Hey @RLango, let me give you a warm welcome to the Community! That is correct my friend. The battery of the Versa should last up to 4 days with normal use. Because battery life is affected by use and other settings, actual results may vary. I suggest you to take a look at the following tips to improve your Versa battery life:
Let me know how it goes!
08-22-2020 01:23
08-22-2020 01:23
Hi, I have tried every tips - including a factory reset to try to sort out the battery life issue my Versa Lite seems to have developed overnight. For 15 months and until last week I had 3 to 4 days life out of it and it only depended on the length of activities. Suddenly it drains overnight! Can we send it somewhere for a battery change? Thank you.
08-22-2020 02:12
08-22-2020 02:12
I have this problem too. I used to get at least 4 days from one charge, but over the past month this has dropped to 2 days and is getting worse. I have already tried the tips they suggest and it makes no difference. How long do these batteries normally last? I have had my Versa for exactly 2 years, and I dont use many of the features to drain it. Is there anything I can do, or is it dying?
08-22-2020 11:07
08-22-2020 11:07
08-22-2020 13:55
08-22-2020 13:55
Until about a month ago, my battery lasted 4 days, and it then suddenly went down to 2 days and is getting shorter. I am disappointed if this means a Versa only la sts 2 years. Is this the expected life?
