04-26-2019
20:25
07:49
JuanJoFitbit
04-26-2019
20:25
07:49
JuanJoFitbit
This happened last night. My versa is displaying unusual active minutes when I have just been lying down. It displayed 128 active minutes at 12 to 2 am and about 1700 calories burnt when I was just lying down and watching tv! Pls help!
Moderator edit: format
04-26-2019 20:52
04-26-2019 20:52
Hi @MegVN restart your Versa several times and hopefully it wont happen again.
Helen | Western Australia
04-27-2019 07:48
04-27-2019 07:48
@MegVN Welcome to our Fitbit Community! Regarding the active minutes, calories burned that your Versa tracked when you were not in activity, I would like to follow up and would like to know if the issue persists or if it got resolved after trying the restart process that shared @NellyG.
If you found her post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! 😀
Best Answer04-27-2019 21:34
04-27-2019 21:34
@NellyG and @JuanJoFitbit - I restarted the device multiple times. Did not help. I checked my versa again this morning and it displays 246 active minutes while I’ve been sleeping. The heart rate display too is erratic. Enters cardio zone while I’m on the couch!
Best Answer04-29-2019 08:08
04-29-2019 08:08
@MegVN Thank you for getting back! I'd like you to try one more workaround that has been helpful for this type of issues.
Please try a factory reset. To do so on your device, open the "Settings" app, then to to "About", then select "Factory Reset". Please make sure to sync your tracker before this in order to avoid losing your data.
Keep me posted on the outcome! 😀
Best Answer04-29-2019 22:41
04-29-2019 22:41
@JuanJoFitbit I did a factory reset. Unfortunately the heart rate is still erratic and and very high. The calorie burn too is disproportionate obviously since the heart rate is crazy. My battery too is draining away in no time. To sum it up, my versa is simply displaying time now and is no more a reliable fitness tracker.
Best Answer04-30-2019 07:17
04-30-2019 07:17
@MegVN I appreciate the time you spent trying the recommended troubleshooting steps. Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Please let me know if you have any questions! 😀
Best Answer04-30-2019 07:26
04-30-2019 07:26
Heart rate and sleep time are not correct on my Versa either.
Think Charge was a better instrument.
05-01-2019 05:31
05-01-2019 05:31
@piet44 It's great to see you in our Fitbit Community! I'm happy to assist you with your Versa since it's not tracking your heart rate and sleep properly.
If you haven't done so, please restart your Versa as instructed in this help article. This will refresh your tracker internally. After this, monitor your tracker and see if it tracks your heart rate and sleep properly.
As a side note, make sure that your Versa is not being worn too tight.
Keep me posted on the outcome! ![]()
Best Answer05-01-2019 06:00
05-01-2019 06:00
Best Answer05-02-2019 08:16
05-02-2019 08:16
@MegVN Thank you for trying the recommended troubleshooting steps. I was able to get in touch with our Support team and was told that they reached you via email recently. Please reply to their email in order to follow up on this issue.
Don't hesitate to get back to us! ![]()
