05-13-2019 14:23
05-13-2019 14:23
Both device and app shows wrong calorie count and active minutes.
Went for a 55 min run, this is registered as an exercise.
In the exercise it shows that I burned 550 calories, but in the calorie count it says that I burned approximately 220 calories in this time.
In active minutes I have a total of 28 minutes for the whole day.
I have deleted app and reinstalled today.
I’ve also restarted the device several times.
I have an iPhone 7.
Can someone help?
05-16-2019 10:52
05-16-2019 10:52
@IngridSV The issue you're describing - calorie and active minutes discrepancies were caused by lack of heart rate monitoring. It seems Versa stopped recording your heart rate after 28 minutes into your run:
That's why you can see a flat line on the calorie chart and empty parts on bpm chart. Please open Settings app on your Versa, scroll down to Heart rate and toggle OFF and ON several times with a reboot of the tracker in between (press and hold the left and bottom right buttons until Fitbit logo appears).
05-15-2019 12:24
05-15-2019 12:24
05-15-2019 14:20
05-15-2019 14:20
Thanks for your answer!
It still doesn’t make sense to me that I only get 28 active minutes for the whole day, when I jogged for 55 minutes though.
Refer screenshots for both calorie count and active minutes.
Seems that calories are correct in the summary for the day (2122), but in details it’s 1758...
Went for a run today as well, and today all data seem to be correct, so maybe it was a temporary problem.
05-15-2019 14:22
05-15-2019 14:22
And here are details for active minutes that day.
05-16-2019 10:52
05-16-2019 10:52
05-12-2020 20:00
05-12-2020 20:00
Hello
I am noticing a decrease in my calories burned per minute recently. It was showing 7-8 calories per min and now it’s showing 3. I am doing the same cycling and even higher heart rate and similar timeframe.
How can this be fixed ?
05-12-2020 22:35
05-12-2020 22:35
Can you please check if by any chance your logged body weight is different?
05-13-2020 05:01
05-13-2020 05:01
05-15-2020 08:20
05-15-2020 08:20
Is someone able to help?
Yesterday my ride was 6 calories a min. Then later in the evening it switched to 3 calories / min. Why is this happening and how can I stop it?
05-16-2020 12:37
05-16-2020 12:37
My weight is the exact same. Any calculator I check at an average 160 heart rate easily shows me at 6 calories /minute. I am not only burning 3 calories a minute. I’m 120lbs. 3 a minute isn’t possible. Help this is driving me crazy !
