04-17-2020
		07:36
		07:18
			JuanJoFitbit
		04-17-2020
		07:36
		07:18
			JuanJoFitbit
My Fitbit becomes frustrating it shuts down totally black and takes a while to come back up. Also after fully charging it it has not yet to last a day before i have to charge again iI did purchase a protection plan with it should i be doing some thing thank you.
04-30-2020 07:17
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              04-30-2020 07:17
Hi @Marypatmoyer, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community.
I'd like to follow up and help you with your Fitbit Versa since it turns off randomly and the battery drains fast.
Please restart your Versa as described in this help article. After this, try the tips listed in this help page in order to improve the battery life of your Versa. Finally, monitor your watch for the next 48 hours and see if the issues get fixed.
Keep me posted on the outcome.
 Best Answer04-30-2020 08:14
04-30-2020 08:14
I have been having the same issue. Twice this week, my Versa 2 screen has gone completely white then shut off completely. I contacted support on Tuesday and they suggested to do a battery test. I fully charged my Versa 2 on Tuesday and re-synced it as they instructed all day Wednesday. This morning, my battery life was at 32% then the screen went white to green then off completely and now won't turn on. I have had this Fitbit since Christmas (received as a gift) and it has died at least 5 times in the past month on me and will not hold a charge. I owned a Alta prior to this and never had any issues with it. I'm very disappointed that this Fitbit, it is defective and a waste of money!! I upgrade as I wanted to capture my exercise more accurately and have had nothing but issues with this Versa 2. I haven't even had the opportunity to use all the apps on it as I'm afraid it will just die. Does anyone know how to fix this issue? I would really appreciate some input on how to fix this.
 Best Answer04-30-2020 08:56
04-30-2020 08:56
My Versa lite, will not charge. I have contacted customer service two times today. Nothing they suggested has worked. I am very frustrated also. My battery was not lasting more than a day. Started charging it last night and this morning I had no charge. I purchased in October unfortunately did not buy protection plan. I am not sure how long the warranty is but I sure hope mine is still under warranty. To much to pay for this and it doesn’t last any longer.
 Best Answer04-30-2020 10:22
04-30-2020 10:22
 Best Answer04-30-2020 13:28
04-30-2020 13:28
 Best Answer04-30-2020 13:32
04-30-2020 13:32
 Best Answer05-29-2020 20:45
05-29-2020 20:45
I have the same issue and Customer was absolutely no hope, I was told that is a known issue from the hardware update and that if your Versa is beyond warranty unfortunately there is nothing that they can do, so basically you run the update and if it fries your Versa there is nothing that can be done.
 Best Answer05-31-2020 07:16
05-31-2020 07:16
