Versa sleep information inaccurate
Kinda bugged my Versa is tracking my sleep when I'm not even wearing it? And when I do wear it, its not even accurate? Any ideas?
1 REPLY 1
It's great to welcome you @Lynnbgirl.
If you have the heart rate feature "On", I recommend setting it in "Auto" or "Off", in this way the watch won't be able to register sleep while you are not using it. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
Let me know the outcome. Smiley Happy
