07-16-2019 20:38
07-16-2019 20:38
I've had my versa since Christmas... The last 3 days it stopped keeping the correct time, and not just random time zones. Sometimes it would be off by a few hours, other times off by 20-30 minutes. I tried to sync, I tried restarting, I read through old threads with various lists of how to fix the issue and none of them have worked. I even tried factory reset... however, now my phone can't even find my versa. So... I'm stuck with a non-functioning Versa until I figure out how to get it sync'ed to my phone so I can redo the set-up.
Please help!
07-17-2019 01:37
07-17-2019 01:37
Hi @MaDeuce What phone are you using? Is it on the Supported Devices List?
Try all the suggestions in THIS Help Article on syncing problems (if you havent already)
Helen | Western Australia
Best Answer07-17-2019 13:57
07-17-2019 13:57
I am having the same issue - time wrong, won't sync, useless to me in it's current state. Have tried every solution offered and nothing works. This started with the latest update. No device found, etc. I absolutely could not be more disappointed - switched from a Garmin and have been extremely satisfied up until now. I am using Android on a Pixel 2. I don't see on any of the threads where Fitbit has offered a workable solution or when a workable solution will be made available. I guess I will go back to Garmin. Anyone want to buy a slightly used inoperable Versa that I paid good money for. Fool me once......
07-17-2019 15:34
07-17-2019 15:34
I am having the exact same issue. When trying to add the versa as a new device the four digit code disappeared almost immediately. Almost like the Bluetooth on the watch disconnects before they sync
07-17-2019 16:39
07-17-2019 16:39
I too am having this same problem and bought mine around the same time... It just started for me last week while I was on vacation
07-24-2019 06:22
07-24-2019 06:22
I have an iPhone Xr. When I first got the watch I had a Samsung Note 5. It had worked perfectly with both phones until just recently.
07-24-2019 22:41
07-24-2019 22:41
@MaDeuce It should work with that phone. I will flag a moderator to come and help you.
02-10-2020 09:14
02-10-2020 09:14
I have an Android Note 10+ and my Versa has stopped keeping time, syncing, receiving texts, etc., as well.
Best Answer02-10-2020 15:44
02-10-2020 15:44
Hi @CityPupMom Have you tried all the suggestions in the article I linked above on syncing issues? If so try contacting Support amd see if they can help.
Best Answer02-11-2020 01:19
02-11-2020 01:19
I have not. I will read through and reply.
Best Answer02-14-2020 06:58
02-14-2020 06:58
