Versa stopped receiving notifications from Android phone
ANSWERED
My Versa stopped receiving notifications a few days ago. I've done a lot of troubleshooting and it still won't receive notifications. It's not even receiving the test call notification. It's still paired to my phone and syncing with the app but I'm not receiving notifications on my Versa. I don't know what else to do.
178 REPLIES 178
Ok so turn off your fitbit and delete the app
Turn your fitbit back on and reinstall the app
It's something to do with the permissions so
Set to allow all all the time and that seemed to work
Call test work and text notifications are back
U will also have to reset the permissions on your phone to what to allow
If this worked for me it will work for you
Got it 👍
Sorry, no. Did all of that twice and still no notifications.
Seemed to have worked for me also
I'm being dim. How do you turn off a fitbit versa 2? I know how to restart one but it doesn't  stay turned off
Didn't work for me
Hi @Jammy2399 - you can turn it off from the watch Settings, About menu with Shutdown.
However if you charge it it will autostart.
No it just restarts it if u hold the Alexa button downSent via the Samsung Galaxy A12, an AT&T smartphone
i did not turn Versa 2 off, Just re-installed App, set permissions for device to access Note20, and checked what apps i wanted to get sent to Versa 2. Seemed to work right away, when I ran the test function in app, it held my previous setting in app.  i just got off work and then went to sleep and did feel versa 2 going off with alerts and woke up to see a history on versa2 when you swipe down from the top of the screen.  So far is working great.  Have read other posts and think fixes may be slightly different set up for app and permissions.... not for sure but worth looking into.  Don't give up, keep on moving
Just done this all and it's not worked for me. 😢
@Guy_ thank you.
Thank you for the information I did this and it still didn’t work. Not sure what I should do. Thanks again
Sent from the all new AOL app for iOS
Same here
I ended up buying a new watch thinking it was maybe on my end. This is my second watch and It's doing it again so I think its definitely a glitch !
Ok, I can confirm (for Android) that the power off/uninstall/reinstall Fitbit app does (seem) to work to bring notifications back.
Previously - this was not a fix - as I had tried that as well as multiple full factory resets of my device as well as several app re-installs. So this does seem to (for the moment) be working as a work-around fix for Android users.
Not sure about Apple users (sorry guys 😞 ) as I do not have an iOS device that I can test with. From the replies in the thread, it seems that iOS users are not seeing this fix the notification issue at this time.
So - until they fully fix this - there is a workaround for Android users.
Android users: Make sure that you are running at least Android ver 12, make sure to install the latest version of the app (35.72.1.19), and make sure to set alllllll of the permissions on reinstall. Keep your device off until you have fully re-configured the app, and then power it back on and sync.
Hopefully this is perma-fixed soon for everyone 😞
Android User - Pixel 4a5g - Android ver 12, Fitbit app ver 3.64 (36419051), Versa 2 firmware ver 35.72.1.19
This did not work for me
Thank you so much! This worked for me on my Android device!
It worked for me...but only for 2 days😒
I just did it yesterday and it is still working (as long as my phone is not
in "do not disturb" mode. I will update if this stops working again!
Where are you finding Android app version 35.72.1.19? The only versions I
can find are nothing close to that number. The version offered on the Play
store is 3.64.5.fitbit-mobile-36419051-462553406.
