10-31-2018
18:38
09:43
AlejandraFitbit
10-31-2018
18:38
09:43
AlejandraFitbit
My Versa stopped registering my heartbeat.
11-01-2018 00:10
11-01-2018 00:10
Have you tried restarting your device by pressing and holding the left button and bottom right button together for 15 secs (until you see the fitbit logo)?
Also on your Versa open the Settings app and find Heart Rate. If it is Off, change the setting to On.
11-01-2018 02:31
11-01-2018 02:31
Please can you be more specific!!!
11-01-2018 04:38
11-01-2018 04:38
11-02-2018 09:45
11-02-2018 09:45
It's great to welcome you @Mjherres11 and thanks for the input @N8teGee, @lenny4d.
I appreciate all the efforts in trying to fix this issue. If you are not seeing your heart rate information on your Versa, I recommend taking a look at the help article Why don't I see my heart rate on my Fitbit device? and follow the instructions provide there.
Let me know the outcome.
11-08-2018 05:12
11-08-2018 05:12
It shows 2hyphens
05-01-2019 15:23 - edited 05-01-2019 15:28
I have the same problem. It worked fine for many months and stopped recently.
I have restarted. I have turned on/off in the watch settings. NO change.
Now only seeing the 2 hyphens.
05-01-2019 15:26
05-01-2019 15:26
My Versa heart monitor worked fine for several months. Now I only see the 2 hyphens.
