11-22-2020
14:33
06:22
JuanJoFitbit
11-22-2020
14:33
06:22
JuanJoFitbit
My heart rate monitor has been recording peak all the time for days and now stopped working completely.
Now the calorie count function has stopped working too
A 2 hour walk was 121 calories. I was with the kids but honestly, I burn more calories asleep!
Performed reset 3 times and no change. Please help!
11-23-2020 06:21
11-23-2020 06:21
Hi @LouisaH77, it's great to see you in our Fitbit Community. I'm sorry to hear that your Fitbit Versa stopped tracking your heart rate and calories burned. I totally understand how you feel about this and I appreciate the time spent trying to get this issue resolved before contacting our forums.
Please try the troubleshooting steps that are listed in this help article. This article contains steps that you already tried but you can skip them and proceed with the rest.
Finally, monitor your watch during the next 24 hours and see if it tracks your heart rate and calories burned properly.
Keep me posted on the outcome.
11-23-2020 06:21
11-23-2020 06:21
11-23-2020 06:41
11-23-2020 06:41
Sorry this was my fail. It hasn't worked. Have reset and shutdown twice and nothing has changed. The heart rate continues to be greyed out. I have also switched the heart rate on and off and back on again.
It has been working fine since I bought the watch last year until recently.
11-23-2020 09:02
11-23-2020 09:02
Hi @LouisaH77, thank you for trying the recommended troubleshooting steps.
I'd like you to try one more workaround, which has been helpful for this type of issues. Please try a factory reset. To do so on your device, follow the steps below:
Let me know how it goes.
11-23-2020 11:18
11-23-2020 11:18
So...
I tried this and then had a red cros saying not synced, try again.
In my wisdom, I then unpaired it with my phone app as it was not syncing and I am sure I read that Incould do this.
Anyway, tries the combination of buttons a few times and I cannot get back to set up.
Will let the Fitbit battery run down and recharge to see if that helps as I cannot get past the red Cross screen.
11-24-2020 08:21
11-24-2020 08:21
Hi @LouisaH77, thank you for getting back and trying the factory reset process. Please let me know how your Versa behaves after letting the battery drain and re-charge it completely. Make sure to charge it for 2-3 hours.
Looking forward to your response.
11-24-2020 09:01
11-24-2020 09:01
I’m having similar problems with my Versa 2. It worked great until the last week or two and the heart rate monitor is not working. I’ve done all of the turn offs and factory resets and made sure that the heart rate tracker was turned on in settings and that it synced to my phone. Nothing is working. The heart rate will inconsistently world and then the green sensor light goes off and there’s nothing. I’m pretty disappointed actually. What should I do?
11-25-2020 08:45
11-25-2020 08:45
Hi @kira_paige, thank you for joining us in this thread and our Fitbit Community. I'm sorry to hear that your Fitbit Versa 2 stopped tracking your heart rate as well.
Since the issue persisted after trying the recommended troubleshooting steps, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
12-06-2020 11:49
12-06-2020 11:49
I have the same issue as well. The heart rate monitor won't work. The lights on the back aren't turning on. I have tried turning the heart rate monitor off and on again, I've restarted it and done factory resets multiple times, I've tried every suggestion in the help articles but nothing has helped. What else can be done? It's extremely frustrating! These cost too much money for people to just say "oh well" and move on to a different fitness tracker.
12-07-2020 10:27
12-07-2020 10:27
Hi @Kastrid, thank you for participating in our Fitbit Community. Thank you also for trying to get the heart rate tracking issue before contacting our forums.
In order to avoid any confusion on my end, let me know what troubleshooting steps you have tried. Also, let me know if the factory reset was performed as listed below:
After this, set up your watch from scratch and see if it tracks your heart rate properly.
See you around.
