03-24-2023
10:47
12:07
AndreaFitbit
03-24-2023
10:47
12:07
AndreaFitbit
03-24-2023 21:22
03-24-2023 21:22
Hi @Von29 - check for the flashing lights on the back of the watch if these are not working when the watch is turned on after a factory reset but the watch is partially working otherwise it is likely to be faulty.
If it accumulated moisture inside it may get hot when charging, if so, stop immediately as it is dangerous.
If the Heart Rate sensor is not working it can't track sleep.
03-24-2023 21:22
03-24-2023 21:22
03-25-2023 07:14
03-25-2023 07:14
Thankyou.
