12-04-2018
16:36
09:04
JuanJoFitbit
12-04-2018
16:36
09:04
JuanJoFitbit
My Versa stopped working. It’s been charging and still not working. I’ve tried the left and right button and holding together for about 15 seconds and hasn’t turned on.
Best Answer@wcmadre This might be the hardware issue. At this point I would reach out to Customer Support to guide you through the next steps. You may need a replacement device.
Best Answer@wcmadre Try performing 3-button factory reset as follows:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If this does not help, you will have to contact Customer Support to guide you through the next steps.
Mine also quit working after less then a week.
I don't think I want another Versa. Seems to be a big problem with them.
I'll probably just return it and get something else?
Best Answer@wcmadre Please do contact Customer Support. They are really good helping people. I am sure they will work with you to resolve this issue ASAP. Good luck!
@wcmadre I'm glad to hear that our Support team sent you a replacement unit. Thank you for posting the update here.
@Bugba Thank you for joining us in this thread and our Fitbit Community! I would like to follow up and would like to know more details about the issue that your Versa is experiencing. Isn't it turning on at all? Did it stop syncing your data? Is it showing anything unusual on the display?
@Marrrmaduke Thank you so much for your help my friend!
See you all later! ![]()
