12-04-2018
16:36
09:04
JuanJoFitbit
12-04-2018
16:36
09:04
JuanJoFitbit
My Versa stopped working. It’s been charging and still not working. I’ve tried the left and right button and holding together for about 15 seconds and hasn’t turned on.
12-05-2018 15:41
12-05-2018 15:41
@wcmadre This might be the hardware issue. At this point I would reach out to Customer Support to guide you through the next steps. You may need a replacement device.
12-04-2018 16:44
12-04-2018 16:44
Try to get it working again by pressing all thee buttons at the same time for at least 15 seconds and see what happens. Also clean the pins of your Versa and the Charger, kindest regards kuzibri
12-04-2018 19:55
12-04-2018 19:55
@wcmadre Try performing 3-button factory reset as follows:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If this does not help, you will have to contact Customer Support to guide you through the next steps.
12-05-2018 04:40
12-05-2018 04:40
12-05-2018 08:51
12-05-2018 08:51
Mine also quit working after less then a week.
I don't think I want another Versa. Seems to be a big problem with them.
I'll probably just return it and get something else?
12-05-2018 15:41
12-05-2018 15:41
12-05-2018 16:06
12-05-2018 16:06
12-05-2018 16:12
12-05-2018 16:12
@wcmadre Please do contact Customer Support. They are really good helping people. I am sure they will work with you to resolve this issue ASAP. Good luck!
12-05-2018 16:21
12-05-2018 16:21
thank you thank you thank you!!!!!!!!!
12-05-2018 18:40
12-05-2018 18:40
12-05-2018 20:04
12-05-2018 20:04
@wcmadre I am so happy you got it resolved! Let's hope for speedy delivery. 😊
12-06-2018 09:03
12-06-2018 09:03
@wcmadre I'm glad to hear that our Support team sent you a replacement unit. Thank you for posting the update here.
@Bugba Thank you for joining us in this thread and our Fitbit Community! I would like to follow up and would like to know more details about the issue that your Versa is experiencing. Isn't it turning on at all? Did it stop syncing your data? Is it showing anything unusual on the display?
@Marrrmaduke Thank you so much for your help my friend!
See you all later!
