12-08-2020
12:32
12:53
12-08-2020
12:32
12:53
Fitbit Versa was working and charging well until it stopped syncing to the iPhone App 2 days ago. Restarted it last night and it finally synced again. Then, I did a factory reset and it has been completely dead ever since. Won’t turn on. Won’t charge. Almost like it was programmed to die since I am getting repeated ads from Fitbit urging me to upgrade.
12-08-2020 12:57 - edited 12-08-2020 12:58
Hi there @DWW2020, welcome to the Community Forums. Thanks for troubleshooting your Versa before posting in the Community.
Please try restarting your Versa once again by following these steps How do I restart my Fitbit device?
If the restart doesn't work and you watch hasn't vibrated during the process, please try the following:
Let me know how it goes.
Best Answer12-08-2020 12:57 - edited 12-08-2020 12:58
Best Answer12-08-2020 13:07
12-08-2020 13:07
Best Answer12-08-2020 13:26 - edited 10-08-2023 04:34
Hi @DWW2020, I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
