12-23-2021
01:17
06:08
12-23-2021
01:17
06:08
I just read some of the comments about the Fitbit not working after factory reset. I had just chatted with customer support about my home button not working and after they helped me fixed it, I thought maybe to keep from having other issues, I would do a factory reset. Well, that was a terrible mistake because now it won’t power back on. I’ve tried holding the buttons but that doesn’t work. If I had only bought it brand new and not secondhand. Now it’s pretty much a loss.
12-23-2021 06:11 - edited 11-14-2023 04:02
Hi there, @Tishbite88. Welcome to the Community Forums. I'm sorry to hear about the issue with your Versa. I understand how you must be feeling.
It seems like the Factory Reset might have drained the battery, but also that the battery may not be charging properly. With that said, please try the following steps:
Hope that helps.
12-25-2021 19:06 - edited 12-25-2021 19:07
Hi @Tishbite88 - see this post about factory resets
It may help to know if it applies to your watch.
Best Answer12-25-2021 19:32
12-25-2021 19:32
