12-28-2020
05:36
05:56
12-28-2020
05:36
05:56
Versa purchased feb 2019, never had an issue near water before. Went swimming in pool today wasn’t in water more than 20mins. Dried versa post swimming put back on noticed screen as blank but light was on. No response when pressing buttons, app cannot connect to versa tried “three button reset” no luck currently sitting in container of rice. Any other suggestions
12-28-2020 05:58 - edited 12-28-2020 05:58
Hi there @Nicjar, it's nice to see you around the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
In addition to the steps you've done so far, please try the following:
If the above doesn't work, at this point I recommend doing a factory reset on your Versa (before doing so, make sure to remove your watch from your Fitbit account):
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Let me know how it goes.
Best Answer12-28-2020 16:02
12-28-2020 16:02
Hi Maria
I have done as you suggested above, cleaned the contacts, tried recharging when connected the versa pebble backlighting comes on slightly but there is no display on the screen or vibrations.
I performed the hard reset “three button” technique and again the back lighting appears to come on/off but no actual visual display or vibrations .
There does appear to be any condensation/moisture around the screen or sensors. I’m wondering if the pebble is just dead?
Best Answer12-28-2020 19:38
12-28-2020 19:38
Call customer support . I had same problem and sent a new pebble . Do before year is up. I wanted it just for the pool and it just messed up the watch
Best Answer12-28-2020 19:44
12-28-2020 19:44
Because I brought in feb 2019 I think I’m outside of warranty period
Best Answer12-28-2020 19:47
12-28-2020 19:47
Best Answer12-28-2020 20:15
12-28-2020 20:15
I have a versa lite and the screen just went blank today also. Was working yesterday fine. Still working as will vibrate and syncing with app. Just blank screen
Best Answer12-28-2020 20:43
12-28-2020 20:43
Just contacted support they are offering replacement pebble
