01-21-2023
05:18
08:33
01-21-2023
05:18
08:33
Went swimming, now not working ?
can I do anything or is it pooched
thanks
01-21-2023 08:34 - edited 05-30-2023 10:14
Hi there, @Grannyof8. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, please try restarting your Versa 2. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work either and your watch hasn't vibrated for the restart process, I'd recommend trying the steps below:
Hope this helps.
Hope this helps.
