05-13-2019 15:36
05-13-2019 15:36
My Versa stopped working today, I put it to charge(it still had some battery left), went to check on it after half an hour. It felt really hot as I took it off the charger and the screen was flashing a bit, then went dead. Half a day later in trying to charge again but nothing... Anyone knows what might be the problem?
05-13-2019 17:03
05-13-2019 17:03
Hi, do not put it in the charger again as you may risk overheating, which is very dangerous. Contact Customer Support asap with this problem, exactly describing what your problem is. Seems to be a hardware problem with the battery.
05-13-2019 17:03
05-13-2019 17:03
05-13-2019 18:21
05-13-2019 18:21
Welcome to the Fitbit Community @EA111 ! It's nice to see you around @SunsetRunner !
@EA111 I appreciate your participation in the Forums and for sharing the details of the issue with your Fitbit Versa. Thank you for your efforts to resolve this. I've shared your case with our Support team and they will continue assisting you on this matter. Please keep an eye on your inbox for further instructions.
@SunsetRunner thank you for your helpful advice!
05-14-2019 10:46
05-14-2019 10:46
Many thanks, I'm now in contact with customer services and I've got a return label for warrantee replacement 👍
05-15-2019 13:15
05-15-2019 13:15
Hi @EA111 ! Thank you for taking the time to reply.
I am glad to hear you're working with Customer Support regarding this matter and will receive a replacement!
Keep on visiting the forums. Happy stepping! ![]()
Best Answer06-10-2022 09:10
06-10-2022 09:10
I have a versa 2 and have been experiencing the same problems.
Best Answer08-11-2022 15:38
08-11-2022 15:38
Just had the same issue. Hoping customer support can help me.
