07-12-2018 06:01
07-12-2018 06:01
I got my Versa this past weekend. I like it, but it seems to be a little high maintenance on keeping the battery life reasonable. However, there's one minor issue that keeps bugging me.
Every morning, after I take it off and put it back on AND enter my PIN code, I have to reset the watch (and enter PIN code again) before it will get my text and other notifications. Otherwise, it just won't do it. Granted, it's not a lot of hard work to reset it every day, but it is an annoyance that I could forget and then stop getting notifications that I need. It's important to me to get notifications because I often can't feel my phone vibrate. Is there any fix for this forthcoming?
Best Answer07-13-2018 13:40 - edited 07-13-2018 13:43
Hey @cdavida, welcome to the Fitbit forums! I think that maybe you have the pin code to unlock your Fitbit watch option as "enabled" which means that you have to enter it each time you put your watch on your wrist. To change the device lock setting, follow this:
If you still not getting notifications after those changes, I would suggest you to try to pair them again from the beginning by following the instructions in this help article.
Now in regards of the battery, with normal use it should last up to 4 days. If this isn't the case, I suggest you to take a look at the tips in this post to make the battery last longer.
Let me know how it goes!
Best Answer07-13-2018 13:54
07-13-2018 13:54
Best Answer07-14-2018 07:17
07-14-2018 07:17
Thanks for your reply and the update my friend @cdavida! Let me ask you this, did you try the instructions to re pair the notifications again as I suggested above? 'Cause you shouldn't reset your Versa everyday to get them. So if you haven't, please give it a try. You can take a look at the instructions in this help article: How do I get notifications from my phone on my Fitbit devi...
Best Answer07-14-2018 10:14
07-14-2018 10:14
Best Answer07-16-2018 07:17
