Versa strap/band's latch fell off, now stuck in Versa....
I was putting a new grey band into my Versa, and as the shorter of the two bands clicked in, the small silver latch that allows you to take the band out and put it in, fell off. Instantly I tried to get the band out, but without the latch it is seemingly impossible. To add onto that, I accidentally put the band in upside down, so I can't really even wear the Versa properly and the upside down band is stuck inside without the latch. I've tried to put the latch back in but it is so small and I cannot even see the hole it is supposed to go into.
Any suggestions? Is the band now permanently stuck in the Versa? I'm pretty agitated right now and really don't know what to do.
1 REPLY 1
Hello @NorthernBit and welcome to the Help forum.  Try a shop that does watch/jewelry repair.  Those pins are used in other brands of watch bands.  Someone with the right fine tools might be able to get it off.
The Versa takes a 22 mm pin.  I learned that when I broke a pin in my Versa.  Amazon sells Versa pins in a reasonable sized replacement package.
Laurie | Maryland
