Versa stuck on Fitbit logo
ANSWERED
My fitbit is just showing the fitbit logo. Please tell me a solution if this has happed with u guys
1 BEST ANSWER
Accepted Solutions
Hi there, @Aadit. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
  • Unpair your Versa from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa again.
  • If there is no connection, restart your Versa.
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
3 REPLIES 3
I haven't used it for about 1 year so it isn't paired.
It isn't paired to my phone
