06-03-2023
19:42
06:33
06-03-2023
19:42
06:33
My fitbit versa is stuck on the logo screen since 2 week. It keep asking to setup.
I have upgraded the firmware multiple times and it goes to success, but device still shows logo and do not go beyond it.
I also tried restarting it, it doesn't work at all.
I have follow instruction to reset as well from below post but that also did not help.
06-04-2023 05:22
06-04-2023 05:22
Hi @jain1609 Have you tried to set it up again? What happens if you do that?
Helen | Western Australia
Best Answer06-04-2023 06:37
06-04-2023 06:37
Hello there, @jain1609. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out. @NellyG Thanks for your help!
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
Best Answer06-04-2023 19:43
06-04-2023 19:43
Thank you @MarreFitbit for response.
I tried your steps multiple times but that did not help.
I am stuck at same place. Watch show the logo and ask for download the app. The app shows the watch is not upto date and keep asking to update it.
