04-05-2018 16:19 - edited 04-22-2018 16:12
Downloaded software for Versa. While it was installing, the process froze. I have done the following to remedy the situation: turned Versa on and off, erased and re-loaded fitbit software on iPhone, Turn phone on and off. Removed versa from Bluetooth discoverable list. No longer discoverable. Disconnected all other Bluetooth devices from Phone. Nothing works because every time I turn watch back on again it returns the frozen installing state (loading bar still on screen) Can’t get help from Fitbit. Any suggestions? Is it possible to reset the Versa to factory settings using the buttons on the sides?
UPADTE April 21/18
So my latest Versa works fine...so far. Did a FIIIT workout today and the watch handled it admirably. Fitbit pay works well, but so far in Canada, only the Royal Bank is on-board -- you can only store a credit card, not a debit card. The biggest pain has been replacing the watch strap, but it's a minor quibble. Will update as necessary.
04-23-2018 11:51
04-23-2018 11:51
My Versa setup has been the smoothest of all the Fitbit products I've bought, but even it was not smooth and the initial update took a long time. All of my Fitibit products suffer bluetooth/wifi connectivity issues, constantly throughout the day. I can't figure out why Fitibt is so bad with their radio work (BT). Even simple syncing with my Charge HR or my fiance's Alta HR, and now my new Versa is problematic. I have spent days trying to setup Fitibt devices before. My only advice is for you to stay persistent and keep trying.
Best Answer04-23-2018 14:24
04-23-2018 14:24
I bought the versa the first day I was able, last Monday the 16th. I have spent multiple evenings trying to get it set up with no success. I have read and done every troubleshooting thing you can think of or read about. I was going to return it today, but then I read that you can setup your Fitbit on desktop computers. I see that many people are having issues with their fitbit and their android phone, which I have (samsung galaxy s7 edge). So, instead of returning it after work today, I decided to come home and give it one more try, setting it up on my desktop mac computer. Of course, I downloaded the "fitbit connect" program and told it that I was "setting up a new fitbit," and then the versa was listed as a product that is "mobile setup only." HA! I guess I am just not meant to own this thing. Such a bummer because I have been lusting over it for weeks and saving my money to treat myself to it just for it to not work for me. Guess I will stick my alta back on my wrist for now, sadly return my versa tomorrow, and maybe try to buy the versa again in a couple of months and hope that fitbit has worked out all of this mess. It puts a bad taste in my mouth though. 😞
04-23-2018 14:38
04-23-2018 14:38
keep trying to beat a dead horse ? this product is retarded.... I went through a 3 hour installation period yesterday . mid day after my workout, I go to sync today and all my stats reset / everything blank!!! im in the middle of resetting and doing this again (3 hours later)... nobody wants to be part of this frustrating product... P.O.S in my opinion and waste of time. Make a user friendly product fitbit!
04-24-2018 05:45
04-24-2018 05:45
(In reply to an Android Authority article)kdkinc
04-27-2018
08:47
04:47
RobertoME
04-27-2018
08:47
04:47
RobertoME
After trying to set my new Versa up since Tuesday and chatting with 3 help desk people from fitbit with no success, do you think I should send my Versa back and get a new one? They say the fix they did was a 'gradual fix' so some devices will take longer than others. They can't give me a time frame, though.
Marne
I tried shutting WiFi off and just using Bluetooth and it said I couldn't set up because there was no signal. How did you do it with just blue tooth?
Moderator Edit: Crossposting
Best Answer04-27-2018 09:30
04-27-2018 09:30
04-27-2018 09:34
04-27-2018 09:34
Best Answer04-27-2018 12:39
04-27-2018 12:39
I sent mine back and got a replacement. New one works fine except it logs steps while I am driving.
Best Answer04-27-2018 23:10
04-27-2018 23:10
Same thing here. This is my first FitBit and it's brutal. I've had it for 12 hours and I'm already returning it to Best Buy. The connectivity is some of the worse I've seen from a device. I'm looking at paying the difference and getting an Apple Watch.
Best Answer04-27-2018 23:35
04-27-2018 23:35
I have an apple 3 watch if you want to buy it off me. I havent used it ever since I got my Ionic. IMO the apple watch sucks at fitness tracking.
Best Answer04-28-2018 05:46
04-28-2018 05:46
Hi, can I ask if anyone has resolved the setting up issue? I have tried all the troubleshooting methods but still stuck at the setting up screen.
Best Answer04-28-2018 06:34
04-28-2018 06:34
Best Answer04-28-2018 07:03
04-28-2018 07:03
I also have tried everything. After uninstalling and reinstalling the app I was able to get as far as the update with wi-fi screen but it will not connect with my network. I have been trying for almost a week to connect and am really frustrated! I have been excited to update to the versa and am now wanting to trow it against the wall!
Best Answer04-28-2018 07:11
04-28-2018 07:11
Right after I posted the last comment my husband suggested trying to connect to the regular network rather than 5G. It connected! Wish me luck on the rest of the process!
Best Answer04-28-2018 08:42
04-28-2018 08:42
04-28-2018 08:42
Hi I have been trying to set up my Versa for 5 days, I keep getting a firmware error when it gets to 6%. I have tried all the recommended things to do with Bluetooth, WiFi etc and still nothing will help. I saw there was a message earlier in week saying there was a problem but then it said it had been sorted.
I cannot get my account to find my WiFi at all.
can anayone help?
Best Answer04-30-2018 17:40
04-30-2018 17:40
Is there anyway to set up without WiFi? I tried to set up and I chose the option use Bluetooth but set up only goes to 6% and cancels. Message on watch indicates watch needs to be updated to newer version.
Best Answer04-30-2018 17:43
04-30-2018 17:43
Hi, I recently acquired my first fitness watch, which has been pretty cool. I however have been unable to synch my watch with my phone using my mobile data. This has limited synchronization to only when I am around my home/ office wifi. Is there a way around this please?
Best Answer05-01-2018 05:07
05-01-2018 05:07
Hello @NikiLetty and @GentleDele, have a warm welcome to the Fitbit Community, it's great to have you both on board. ![]()
@NikiLetty, please note that it's recommended to update your Fitbit Versa using WiFi as updating it through Bluetooth will result in a slow process that might get cancelled. Using WiFi will improve the speed of the update.
@GentleDele, if your watch is not syncing correctly using mobile data, I would like to suggest you to check the following:
If your device still won't sync, try these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
Best Answer05-01-2018 07:25
05-01-2018 07:25
Hello- What if you can't get into the fitbit app? I installed the app last night from my home and it stayed on "2 of 3" for almost an hour, so I turned off my phone. This morning I tried it again from work and it stayed on "1 of 3" for 30 minutes so I uninstalled the app and re-installed it using my work wifit. Now it's saying "Fitbit is down for maintenance".
:/. Please help!
What would I like to see? Wow!
Let us start with an analogy. If I buy a new automobile I expect the automobile to start.
When I select "drive" I expect to go forward, all pretty simple stuff I hope you all agree.
Now when I bought my first Versa I expected it to update and connect to my Google Pixel 2 XL. I mean why not?
So enter replacement number two. Same issues twice as frustrating. I know what do I expect for $200.00, quality silly me.
Dear Fitbit once upon a time Ford Motor company had a new top of the line automobile called the Edsel.
Versa is the new Edsel a clunker.
