05-02-2018 05:04
05-02-2018 05:04
I noticed my Versa started to act strange when it wasnt recording my sleep or sending me notifications during the day. Then this morning I woke up to the screen being stuck on the fitbit logo. Every now and then it will go black and then the logo will reappear. It wont let me turn off/on. I did put it on the charger and it charged. Not sure what to do now with the screen constantly on.
03-13-2019 23:29
03-13-2019 23:29
did you ever get it to work?
03-14-2019 05:13
03-14-2019 05:13
03-16-2019 15:19
03-16-2019 15:19
I went through every possible scenario suggested by the Fitbit support team, as well as things that I read here, and other things that I found on the Internet. My Fitbit versa was stuck in “fetching” screen. It would flash the screen on and off every second or so, and continued saying the word fetching. I deleted and downloaded the Fitbit app, I turned on and off the Bluetooth, and the wireless, I did a factory reset… Nothing was working it would flash the screen on and off every second or so, and continued saying the word fetching. I deleted and downloaded the Fitbit app, I turned on and off the Bluetooth, and the wireless, I did a factory reset… Nothing was working. Then I decided to try to download another clockface and viola’ — it worked. Seems the clockface I was using was the problem! My Fitbit is now working, receiving texts, alerts, counting my steps etc.
03-16-2019 20:21
03-16-2019 20:21
05-08-2019 01:57
05-08-2019 01:57
This worked smashingly!!!! THANK YOU!!!
05-24-2019 06:35
05-24-2019 06:35
mine is doing the same thing...bought in Dec 2018. Normal usage and don't swim with it. Quality product. NOT!
06-03-2019 22:19
06-03-2019 22:19
Having the same issue 😔
06-05-2019 17:55
06-05-2019 17:55
This is happening to me too. Has it been resolved?
06-05-2019 18:02
06-05-2019 18:02
Thank you so much for your help on this issue. I did this and it rebooted. Yay! Hope it stays this way. 👍
06-07-2019 01:53
06-07-2019 01:53
Thank you too! I had the same problem and I fixed
06-13-2019 13:50
06-13-2019 13:50
Exact same thing happened to me! Customer support said it was a battery issue and sent me a new one.
07-04-2019 23:17
07-04-2019 23:17
e was bought as a xmas present dec 2018 and doing same. How do I contact customer support
07-20-2019 12:27
07-20-2019 12:27
I just pressed all 3 buttons simultaneously and it went back to normal.
07-30-2019 06:07
07-30-2019 06:07
Logo screen is gone now, briefly it showed 0% battery , now nothing , imagine the battery is dead as a dodo at this stage , won’t charge either, this is my 2nd Versa in less than a year . Started glitching the other day , had a feeling something wasn’t right , so annoyed as I’m signed up to 100 miles in August for charity , & my Versa is defunct
11-27-2019 19:50
11-27-2019 19:50
How do you do a theme reset?
12-03-2019 14:23
12-03-2019 14:23
Mine is doing the same thing! I've had it for less then 5 months and its been acting up for the past few weeks like first every time I tried touching the screen it turned off,it turned black even when I changed the setting back to manual and not auto motion on and it still did it took me 5 mins thi even be able to get into the settings freon the watch itself every single time I touched it turned off instantly, NOW its an even worse problem I woke up a few days ago and it is stuck on the sleep mode I can't evan get my notifications I can't do anything I can't even into the calculator so its not instantly going black anymore it just doesn't do anything I can't even shut it of . I let the battery drain completely out and I charged it over night and it was ok the next morning well I was able to get the sleep mode off it still does the black out screen the second I touch it but at least I can't get my notifications but once again at night i put it on sleep mode and it's doing it again i can't even shut it off like wth i have to drain out the battery AGAIN like it's too much and don't know what to do about i . I saved up every penny I got to get thing and not even 5 months later this starts like wth. So upset
12-03-2019 18:27
12-03-2019 18:27
Mine is doing the same thing. This is my second Fitbit Versa Lite due to problems with the first one. I contacted support and they sent me the one I have now. Now I'm having issue with this one. I'm really disappointed in this product. I've tried resetting, I don't have three buttons on the Versa Lite, so I don't know how to factory reset. Please help. It's great when it works! Thanks!
12-04-2019 04:41
12-04-2019 04:41
12-11-2019 01:23
12-11-2019 01:23
Yes
mine is a Fitbit Versa Lite and I can't hold the three buttons. What did you do with your Versa Lite?
12-11-2019 03:24
12-11-2019 03:24
