06-29-2021
22:18
08:55
06-29-2021
22:18
08:55
Hi,
I tried to restore the factory settings. However after the action, the watch is showing error message as " Data not erased completely , sync and retry". However since the device is removed from login id, i am not able to sync. I tried switching off and on several times but still the same error messages. when i am trying to sync as new device addition, the connectivity could not be established. kindly help.
06-30-2021 09:02
06-30-2021 09:02
Hi there, @rajvishnu. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
That message usually appears when you performed a factory reset without unpairing the Fitbit. Usually you should unpair your Versa, forget Bluetooth and perform the factory reset. To solve this issue, try these steps in the following order:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
06-30-2021 22:03
06-30-2021 22:03
Hi,
I tried to disable the Bluetooth connection from my mobile .. I had infact removed the device from my app id. still the same error comes. Now i cannot add back the device and sync the device due to the error.
07-01-2021 03:49
07-01-2021 03:49
@rajvishnu I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
07-07-2021 05:56
07-07-2021 05:56
Hello, I am having the same issue. Were you able to fix it? If so, please tell me how.
