01-22-2023
06:35
08:44
01-22-2023
06:35
08:44
When I can’t setup my versa either Bluetooth and Wi-Fi I try to reset the watch then I got an error “data not cleared . Sync and try again. But I can’t sync as it was not setup in the first place. Please advise me
01-23-2023 08:46
01-23-2023 08:46
Hi there, @drgsrao. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, as @Guy_ has recommended, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Nevertheless, I've seen you contacted our Support Team after posting. Please stay tuned to your inbox, someone will reach out to you soon.
See you around.
Best Answer01-23-2023 02:23
01-23-2023 02:23
Hi @drgsrao - Try this without the italics step, if it doesn't work try with it.
Best Answer01-23-2023 08:46
01-23-2023 08:46
See you around.
