07-09-2019 08:21
07-09-2019 08:21
Versa suddenly died, no reaction to charge or reset.
02-01-2020 16:13
02-01-2020 16:13
02-01-2020 17:02
02-01-2020 17:02
The three buttons are on the old Versa, not the Versa 2.
If they replace it for free I'd go for it.
Otherwise maybe try holding the one button down to see if it resets (maybe even a minute or two).
Best Answer02-01-2020 19:50
02-01-2020 19:50
Am having the same issue. Tried holding the 3 buttons for 3 minutes (literally) and got nothing but the red empty battery icon with 0% flashing every so often. It’s actually at 58% and won’t charge. Happened from one minute to the next. Any other solutions? Thanks!
02-02-2020 20:20
02-02-2020 20:20
I'm having a similar issue. Just out of warranty and the device quit working no matter which "fix" I apply. It seems to be a common issue after the last update, yet Fitbit won't take responsibility for it. It almost seems as if the latest update was meant to cause them to fail.
02-02-2020 21:35
02-02-2020 21:35
Best Answer02-04-2020 16:32
02-04-2020 16:32
Hello everybody. It's great to see you in the Fitbit Community
@RainierGirl, like mentioned by @cshelley, the steps mentioned above to perform a restart are intended to the Fitbit Versa. The Versa 2 can be restarted by following these instructions.
Since you have contacted Customer Support, I would recommend updating them to get further assistance.
@NAG88 @Ang1972, I'm glad to hear that your experience with Customer Support was great. Thank you for letting us know.
@cshelley, thanks for your comments.
@Kotterrock, I regret to hear that your issue wasn't resolved. Our team is constantly working to improve our products and services. Your feedback is highly appreciated.
If you have any question, please don't hesitate to contact us back at any time.
Best Answer02-07-2020 08:29
02-07-2020 08:29
THANK YOU! THANK YOU! THANK YOU!
I thought my fitbit was dead but this worked like a charm!
Thank you so much for this fix.
02-09-2020 16:34
02-09-2020 16:34
Welcome to the Fitbit Community @ladyjustice7,
It's great to hear that you've been able to resolve the issue with your Fitbit Versa. Thank you for letting us know.
Feel free to contact us back at any time.
Best Answer02-11-2020 18:53
02-11-2020 18:53
Yep same thing here. I have the versa special edition and I've had no issues with battery at all. Now out of nowhere after the update it does and wont respond to charge or reset. Its barely over 1 year warranty and low and behold there is nothing that can be done. But oooh we'll give you a discount in case you want to spend a bunch of money on another device that will break in little over a year 🙃.
02-12-2020 20:26
02-12-2020 20:26
Best Answer02-13-2020 00:00
02-13-2020 00:00
Hello i tried all the things listed above and my versa is not working. what should i do? i tried contacting support but it said there was an error.
Best Answer02-13-2020 15:02
02-13-2020 15:02
@Rebekah888, I'm sorry to hear that your Fitbit Versa Special Edition doesn't respond to charge or reset. Thank you for letting us know that you've been in touch with Customer Support already.
@Ang1972, thank you for letting us know how you've resolved the issue with your Fitbit Versa. I hope this helps other users experiencing the same problem.
@photoxliz, to evaluate your situation, I created a case with Customer Support. Please check your inbox on the next days. They will let you know how to proceed.
If you have any question, please let us know.
02-16-2020 11:32
02-16-2020 11:32
After reading all the similar complaints about Versa suddenly not charging or turning back on as mine was doing, I tried the remedies mentioned. Nothing helped. Called Fitbit support, again tried the reset. Did not work. One month out of warranty and the only suggestion was to buy a new Fitbit. $200 for a Fitbit that lasts 13 months and they only suggest purchasing another one. From all the complaints it appears there is an inherent problem with the device and they do not stand behind their product. Fitbit should be ashamed of themselves. Truly deceptive company that is only concerned with sales and not recalling and replacing defective products.
02-16-2020 12:09
02-16-2020 12:09
your fix worked for me! Thnx!!!!
02-16-2020 12:20
02-16-2020 12:20
??? What fix?
Best Answer02-16-2020 15:00
02-16-2020 15:00
02-16-2020 18:07
02-16-2020 18:07
Thank you so much. Worked for me.
02-17-2020 06:36
02-17-2020 06:36
Tried that. Didn't work.
02-17-2020 07:27
02-17-2020 07:27
Thanks so much! This worked
02-17-2020 07:31
02-17-2020 07:31
Just curious can you get to about screen and tell us which OS version your Versa is running?
Thanks
