06-28-2018 02:38
06-28-2018 02:38
Since somepoint yesterday whenever I swipe up, down or sideways, or press any of the 3 buttons only the calculator appears, cannot get rid of this. I have synced numerous times, even deleted and reinstalled the versa, even rebooted twice and still have this issue.
Best Answer06-28-2018 05:40
06-28-2018 05:40
Are you sure it's a calculator and it's not asking you to enter a security PIN?
Have you set up fitbit pay as this turns on PIN security automatically.
06-28-2018 05:40
06-28-2018 05:40
06-28-2018 05:59
06-28-2018 05:59
@SteveH wrote:Are you sure it's a calculator and it's not asking you to enter a security PIN?
Thanks for not being rude.
@NicNacF Does the calculator have buttons for "+", "-", "×", "÷"? If not then it is definitely not a calculator.
Best Answer06-28-2018 07:08
06-28-2018 07:08
Thank you, you are correct, it was asking for a pin, doh!!
06-28-2018 07:08
