Has anyone noticed a relationship between sync failures and battery level / power?
My versa syncs ok for a day or so, but seems totso truggl when battery falls below about 50%.
Charge it or just put it on the charger and its happy again!
I have seen lots of posts about sync failing after a period of time. Could this be a power issue?
Best AnswerThen its back to the usual suggestions of cyling bluetooth off and on, then restart watch and then restart phone /app, in my experience.
Just wanted to know if others had identified battery charge as a factor
Best AnswerI also switched OFF
All day sync
Keep alive and
Always connected
Only syncs when I open the phone app, but seems to sync more reliably and phone battery lasts longer!
Best AnswerI don`t know if there is a `back door` to these watches, but soon after posting the above, I noted that battery drain had increased. maybe just co-incidence, but seems to be a significant issue.
Last night, I gave up and wiped EVERYTHING, including the phone app and resetting the watch to factory status, then re-installing and updating. Took 3 hours after pushing through numerous hangups in the process (eg found versa, but failed to connect)
Since 10:00 am (5 hours), battery has lost 15% (IE Predicted battery life of 33 hours and NOWHERE NEAR 4 days!)
So now I am checking and testing:
Watch
- charging to 100%. Restart watch.
- Screen awake = ON
- Notifications = ON (for now, as what is the point of smart watch, otherwise)
- No alarms.
-Display awake = 10 SECS
Heart rate = ON
Phone App
- setting All day Sync = OFF
- setting Always connected = OFF
- setting Keep Alive Widget = OFF
Will re-post with progress.....
Best Answer... no sync since last night (approc 5 hrs after initial post.). So trying to sync:
1. manual sync from app x 5 failed. No message.
2. restart app and manual sync attempts. Failed.. `Tracker not found`
3. force stop and restart app and manual sync attempts. Failed.. `Tracker not found`
4. restart bluetooth and restart app and manual sync attempts. Failed.. `Tracker not found`
5. shut down and restart Versa via menu and manual sync attempts. Failed.. `Bluetooth Issues`
6. shut down and restart Versa via pincer grip and manual sync attempts. Failed.
7. Use `Restart Bluetooth` option. Automatic sync failed (no messages) and manual sync attempts. Failed..No messages.
At this point, I am looking at re-installing the app. and / or re-pairing with the Versa.
- It REALLY should`t be this difficult!
- Battery consumption appalling (now at 44% after about 18hrs)
Hugely unimpressed.
Any other suggestions, please.
Best AnswerJust got off the phone from Customer support.
Apparently the above is not a proper test as I did not turn off
- Notifications (pretty vital function for a smart watch)
- Screen Awake (one of the features that first attracted me to the product)
- Heart rate monitor (the other feature that attracted me to the product)
So here we go again.......
Best AnswerResult::
Well it stopped being able to sync after around 48hrs (after still declaring battery at 75% an hour or two earlier), then died shortly thereafter.
