04-20-2018 13:53
04-20-2018 13:53
My phone and Versa are actively syncing but I am not receiving any notifications. The fitbit app does not give options to turn notifications on or off for messaging, phone calls, email, or my calendar. Bluetooth is connected, do not disturb is not enabled, and all my app notifications are turned on on my phone. I've gone through the troubleshooting guides and can't figure this out.
07-29-2019 14:46
07-29-2019 14:46
My verse lite and iPhone are paired together. The Bluetooth is on. But I’m not receiving notifications. I have gone to account and clicked the notifications and sync all day and it only swirls around the little circle that tells you it’s doing something. But it never does. I have tried to delete my versa and repair it and still same thing. Help please
07-29-2019 17:33
07-29-2019 17:33
@Kcoke wrote:My verse lite and iPhone are paired together. The Bluetooth is on. But I’m not receiving notifications. I have gone to account and clicked the notifications and sync all day and it only swirls around the little circle that tells you it’s doing something. But it never does. I have tried to delete my versa and repair it and still same thing. Help please
Kcoke: When I had the problem where the Versa wasn’t receiving notifications, I somehow restarted my iPhone, which is one of the things I do in problems like this. Push and hold the sleep/wake button (or for iPhone X and up, press and hold the right and left top buttons until the shutdown prompt appears. Slide the button to the right. The phone shuts down. Wait about 15 seconds, then press the top or right button until the phone restarts. After you’re fully restarted, your Versa may start getting a storm of notifications! That’s what happened to me. If so, you may not have to do this again.
However, this is NOT related to the problem where you can’t clear notifications off the watch. Rather than tell you to go somewhere else for that solution, here it is:
On the watch only, swipe the watch face to the left until you see the Settings icon, then tap on it.
Swipe UP until you see “About”. Tap “About” and swipe up until you see “Shutdown”. Tap Shutdown, and the watch will Shutdown. This is not the same as Factory Reset. If you push and hold the left button on the watch, it will restart.
After restarting, the problem of inability to clear notifications should be solved.
However, DO NOT clear future notifications ON THE PHONE! This may cause the Versa to be unable to clear all notifications again, and you will have to do the “Shutdown” thing again. Be prepared to do this again until the proper fix is released by FitBit.
Like this post? Please tap on the “Thumbs Up” button to tell me!
Best Answer08-06-2019 21:46
08-06-2019 21:46
Finally u answered the question yay!
Best Answer08-08-2019 19:03
08-08-2019 19:03
Oh my gosh. This was my fix!!! Thank you!!!!
Best Answer08-10-2019 07:34
08-10-2019 07:34
Thank you so much! I tried everything else that was recommended and nothing worked...until now!
Best Answer08-10-2019 14:24
08-10-2019 14:24
@pamv98 wrote:Thank you so much! I tried everything else that was recommended and nothing worked...until now!
So glad it worked for you 😊
08-13-2019 12:59
08-13-2019 12:59
THANK YOU! THANK YOU! THANK YOU!!! I've been working on this for hours and your quick trick was the fix!
08-13-2019 13:38
08-13-2019 13:38
@jennynic2 wrote:THANK YOU! THANK YOU! THANK YOU!!! I've been working on this for hours and your quick trick was the fix!
So pleased it worked it’s a frustrating thing to find but once you do it it’s fab!
Best Answer08-14-2019 07:23
08-14-2019 07:23
This was finally the answer I was looking for. How simple that fix was. Thank you, thank you!!!
Best Answer08-20-2019 09:10
08-20-2019 09:10
Thank you!! This issue has been driving me crazy. My settings must've changed after I performed an update. I never went to the last screen to allow FitBit notifications. Thanks, again!!
Best Answer08-24-2019 07:13
08-24-2019 07:13
Thanks....that did the trick!
08-24-2019 10:09
08-24-2019 10:09
@heide930 wrote:Thanks....that did the trick!
Fantastic!
08-26-2019 11:55
08-26-2019 11:55
Hi everyone! I'm sorry for the late response. However, It's great to hear that the info that shared @SunsetRunner was helpful. Thank you for posting the update here. The information is greatly appreciated.
As a side note, I'd like to invite you all to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! ![]()
Best Answer08-28-2019 10:29
08-28-2019 10:29
c'mon.
Best Answer08-28-2019 12:55 - edited 08-28-2019 13:01
One possible solution: Hold the left single button for 2 seconds until it vibrates and brings up the Screen Wake and Notifications button - then you should see if Notifications are on or off and you can tap to change.
Best Answer08-28-2019 12:56
08-28-2019 12:56
Best Answer08-28-2019 13:05
08-28-2019 13:05
Best Answer08-28-2019 15:43
08-28-2019 15:43
Thank you for this. I also inadvertently turn my notifications off.
Best Answer08-30-2019 17:13
08-30-2019 17:13
Ahhhh, thank you!! I don't remember turning notifications off there, and frankly, I think it must have happened accidentally. I was going through all sorts of more complicated things to fix this issue. THANK YOU for this info. I seriously would have never found that. So stinking simple too.
Best Answer09-01-2019 07:06
09-01-2019 07:06
