04-20-2018 13:53
04-20-2018 13:53
My phone and Versa are actively syncing but I am not receiving any notifications. The fitbit app does not give options to turn notifications on or off for messaging, phone calls, email, or my calendar. Bluetooth is connected, do not disturb is not enabled, and all my app notifications are turned on on my phone. I've gone through the troubleshooting guides and can't figure this out.
09-17-2019 18:56
09-17-2019 18:56
Oh my god you saved my life!!!! Thank you
09-22-2019 19:56
09-22-2019 19:56
Anyone know how to get to this screen on the Versa 2? This fix worked for my wife's Versa but holding the left button on Versa2 is now a shortcut to Alexa/Fitbit Pay
09-24-2019 09:38
09-24-2019 09:38
omg! Me too!
09-25-2019 04:17
09-25-2019 04:17
Solved this, I just had to un-install the Fitbit app on my phone, then re-install and set-up notifications again. Now working fine
09-25-2019 04:52
09-25-2019 04:52
09-25-2019 06:36
09-25-2019 06:36
GogoGranny:
When I get a “Device cannot be found” message, it’s because I have Bluetooth turned on on BOTH my iPad and iPhone. Solution is to turn off Bluetooth on my iPad or whatever is interfering. Sometimes I also have to close the Fitbit app and restart it. Then all is well!
10-01-2019 12:48
10-01-2019 12:48
thank you! ive been trying everything and this worked.
10-01-2019 14:19 - last edited on 07-05-2021 16:15 by LiliyaFitbit
Hasn't worked
10-01-2019 14:41
10-01-2019 14:41
Have a look at my earlier post I side loaded using app an this worked.
10-20-2019 07:36
10-20-2019 07:36
Didnt work for me either 😡
11-01-2019 14:03
11-01-2019 14:03
After doing the recent iOS 13 update my versa was not giving me notifications. Finally after several weeks it is working again. Think it’s a combination of a few things I did. I did the most recent iOS update 13.2 (with bug fixes). I then removed my versa completely from my app (remove this device) and deleted the Fitbit app. I reinstalled the app then reinstalled my Fitbit Versa to the app. Works perfectly now!
11-01-2019 15:43
11-01-2019 15:43
11-01-2019 16:04
11-01-2019 16:04
Sorry it hasn't worked. I know it's so frustrating. It did take about an hour after I did all this for it to start working again cuz the notifications from other apps need to be set up etc.
11-08-2019
01:17
04:19
JuanJoFitbit
11-08-2019
01:17
04:19
JuanJoFitbit
Hi,
Is this problem fixed yet? It's infuriating.
Having followed every piece of advice, method, and tip in here I'm still left with a smart watch that isn't sending me notifications. So not that smart!
Please advise.
Thanks
When I do this, I don't have a notifications toggle. I have 4, but none relate to notifications.
Moderator edit: merged reply
11-08-2019 11:17
11-08-2019 11:17
11-27-2019 20:19
11-27-2019 20:19
Deleting my Fitbit then deleting and reinstalling the app worked for me. Make sure your do not disturb is off on your phone.
12-04-2019 08:09
12-04-2019 08:09
This seems to work for me too but it is really frustrating but possibly the fastest way instead of trying to figure out Bluetooth, app notification etc settings when I know none of those were altered.
I have an android phone and all notifications keep coming to my Versa 2 UNTIL I turn off/on my phone or it restarts for some reason and at that point my only possible resolution having tried every single one of them recommended by fitbit or fellow users is to uninstall and reinstall the app.
12-04-2019 08:29
12-04-2019 08:29
Doesn't seem to work for me, it looks like those are just the Fitbit App Notification and not the notifications from other apps.
12-14-2019
10:28
04:18
JuanJoFitbit
12-14-2019
10:28
04:18
JuanJoFitbit
This fixed mine.
I am disappointed as well, should have stuck with my fitbit VERSA, I had no problems. Just when I think I fixed the notifications, they stop again.
12-20-2019 09:44
12-20-2019 09:44
I'm the same, have tried everything suggested and nothing has worked. And yes, it was working fine one day, and out of nowhere nothing, no notifications. This is so fustrating!!!
