04-20-2018 13:53
04-20-2018 13:53
My phone and Versa are actively syncing but I am not receiving any notifications. The fitbit app does not give options to turn notifications on or off for messaging, phone calls, email, or my calendar. Bluetooth is connected, do not disturb is not enabled, and all my app notifications are turned on on my phone. I've gone through the troubleshooting guides and can't figure this out.
02-11-2019 18:37
02-11-2019 18:37
Thanks Hev14! Your solution saved my sanity. It was so simple, yet it wasn’t mentioned anywhere else! 🙏
02-12-2019 00:40
02-12-2019 00:40
@JEPS wrote:Thank you! So simple and yet ...not mentioned anywhere else! 🙏
Glad it helped
02-12-2019 16:10
02-12-2019 16:10
This one actually worked for me on iPhone! So simply yet fixed my issue.
02-13-2019 00:26
02-13-2019 00:26
@Gaaabbbsss wrote:This one actually worked for me on iPhone! So simply yet fixed my issue.
Glad to help
02-13-2019
09:49
08:12
02-13-2019
09:49
08:12
Hey @JEPS and @Gaaabbbsss, welcome aboard! Sounds great that your Versa are working fine now. If you have further questions or comments, let me know!
Have a nice day!
02-13-2019 13:24
02-13-2019 13:24
02-13-2019 13:52
02-13-2019 13:52
02-13-2019 18:43
02-13-2019 18:43
I have to keep doing this process multiple times a day to get notifications the whole day.
Getting super frustrated
02-13-2019 21:38
02-13-2019 21:38
Exactly right , it's pretty annoying to keep doing this multiple times a day to get the notification .I think Fitbit team has to take it as a serious note and get resolved
02-16-2019 06:19
02-16-2019 06:19
Hi everyone i have read and tried everthing as well, have now a third party app that works with Fitbit called Fit Notifications and seems to be working well, it transfers phone, text and email notifications from the fitbit app, i disabled the call button in the fitbit notification app also. I hope this helps because i have looked for days for a solution, you would think a company like Fitbit could sort it out.
02-16-2019 07:06
02-16-2019 07:06
02-16-2019 09:11
02-16-2019 09:11
No sorry I don't.
02-20-2019 07:41
02-20-2019 07:41
THANKS LS643 THIS ACTUALLY WORKED.
02-27-2019 05:10
02-27-2019 05:10
How do i unpair my versa
02-27-2019 05:26
02-27-2019 05:26
@Lee819 wrote:How do i unpair my versa
If you go in to your fit bit app either on your phone or desktop and click on your verse it gives you the option to remove the versa
03-14-2019 13:37
03-14-2019 13:37
Literally my lifesaver!! I tried EVERYTHING else several times..even on the phone with fitbit couldn't figure it out... so simple...Easy fix!! Thanks so much for sharing!!!
03-14-2019 15:08
03-14-2019 15:08
So what was the solution that made it work? I don’t see a fix in the message string. I’ve tried everything, but mine still doesn’t work properly.
03-14-2019 15:14
03-14-2019 15:14
Mine has stopped working again and I am having charging issues again.
03-14-2019 15:15
03-14-2019 15:15
It hasn't been fixed, which is why I've moved on. Almost 3 months of this ridiculousness. Something tells me if I picked up a Versa Lite, it would work perfectly, though. Funny how that works.
03-14-2019 19:39
03-14-2019 19:39
