Hi, I have the same problem from the beginning, but I found a solution for it:
" The workaround is to go to Fitbit.com/Dashboard on your PC and enter, every day, the time of going to bed (mind changing the date if necessary) and waking up. After having done that and syncing with my Smartphone it shows the sleep. Although this seems pretty annoying, it will only take a minute of your time and you will have your sleep on your mobile device.
