07-05-2018 00:03 - edited 07-05-2018 08:54
Dear Fitbit,
there are numerous different forum posts and literally hundreds of testimonies from different users who just can't get their Versas to sync reliably (regardless of phones or platforms they use) or at all. Many were forced to return the product they really wanted to like.
My question for You is: is there ever going to be a fix for this or is this a massive, unrepairable fail - an inherent hardware issue?
As for my problem, here's a description and a partial solution I was able to find after wasting hours of my life for problem solving of a brand new 230€ product. (This alone is unacceptable for any respectable company.)
Background and issue description:
I bought a Versa Special Edition from German Amazon two days ago. Everything looked good, initial set up with my LG G6 went well. After that, issue after issue. Firstly, no notifications. None at all. Not even a test call from Fitbit app worked. This forced me to Google and then Google again, in vain attempt to find a solution. In the process, I learned that LG G6 is not supported (for unspecified reason, Fitbit decided to ignore LG phones after G3), whatever that might mean. I had never even thought this was actually possible. In the world of mutually compatible Android devices which use the largely the same hardware and communicate with the same standards (BT, WiFi, LTE, etc.), there actually exist supported and unsupported phones? I figured this was bull* and did not back up. If MiBand 2 for 16€ can be compatible with pretty much everything, Fitbit must be as well. After all, the only suspect issue is Bluetooth, the communication protocol.
Looking for a solution:
So I tried literally all the repetitive suggestions I was able to find here or elsewhere. I.e. restarting, factory reseting, unpairing/pairing, playing with various combinations of syncing/notification settings, uninstalling/installing. Nothing. Still no notifications. In fact, after a couple of hours, I noticed that the issue will be with synchronization, not notifications themselves. The Versa was actually unable to sync at all, while being paired successfully. And yet, the initial setup worked just fine. I began to suspect that this was a Bluetooth comunication issue. Yes, it was paired, but the information didn't trasfer correctly. Fitbit app began giving an error for synchronization. I found that unpairing the device in phone settings and restarting the app made it establish a connection for a while and sync some data - just for a while. Then stopped working again, error again.
What finally worked (sort of):
In my despair (really, how in the world is this possible when 60€ unnamed Chinese watch with almost equal abilities - despite being suitable for swimming - to Versa just works and works reliably all the time?) I enabled the developer mode on my G6 and looked for Bluetooth options. Found that AVCRP was set to 1.5 as opposed to 1.4 default setting. So I set it to AVCRP 1.4. Voilà, that fixed the connection. For whatever reason. I have no idea why changing this particular protocol setting worked, but everything suddenly worked and worked beautifully. For 24 hours. This morning the synchronization stopped working again. Until I unpaired Versa from the phone and relaunched the app. Now everything works again. But how long? How reliably? That's the question...
Should I return the Versa? Or is there any hope this will be fixed?
07-05-2018 03:35
07-05-2018 03:35
I am so disappointed. I love the look of my Special Edition Versa and have been getting complements from others about how good it looks but it has now stopped syncing. It worked for about a week and now I have been trying for about two weeks to get it syncing again. I've deleted the app on my phone and re-installed. Still nothing. It sits there forever saying Connecting to Tracker and nothing happens. Is there a fix or do I need to ring up and get my money back? Maybe I should have went with the apple smart watch. Not happy at all.
Best Answer07-05-2018 09:03
07-05-2018 09:03
I am more and more convinced the issue is communication over BT, thus - at least in theory - should be quite easily fixable. But why then is it taking them so long? Perhaps something else as well... Today I went biking and Versa failed to track my ride or speed, even though the rest of the data synced. Versa just couldn't get the GPS info from my G6, even though the GPS was on and permission was granted. "Connecting..." was flashing on Versa's display. Never connected. Did a little bit of research and found one of the biggest competitor's offer is very capable and just a little bit more expensive than the Special Edition. However, I really don't want to return or exchange the Versa. I really like the design and the functions. And I also like the platform. If the watch just worked...
07-05-2018 10:42
07-05-2018 10:42
I purchased a Versa a few weeks ago and it worked fine until 30 June. Since then it will not synch. In chats with the help desk I thought I had a fix; however, the same problem reoccurred.
07-05-2018 12:27
07-05-2018 12:27
I determined to solve the connected GPS issue. Came across the myriads of forum posts having the same - once again - unsolvable problem. Yet another.
So tonight after wasting another couple of hours of my life tring to squeeze at least some life out of the Versa a decision has been made: return to Amazon.
I'm most probably going for Garmin Vivoactive 3. No similar issues reported there.
Best Answer07-06-2018 03:43
07-06-2018 03:43
Very similar issue here.. I thought it was to do with the set up and connection, tried all the suggested troubleshooting and some of them worked.. randomly, sometimes... Other times I did nothing and after a few hours the syncing would start working perfectly again.. for a short while. It has also cut out during swim tracking (very annoying).
I have noticed that the watch sometimes goes into a "fit" where it restarts itself every few minutes. I think this may be linked to the connection issues? It would make sense that if it decides to restart mid-swim that the tracking stops! I've also noticed the battery life drops rapidly occasionally.. again this may be due to the restarting.. Eg yesterday it was syncing fine, from 4:30pm to midnight only went down from 99% to 93% battery. Before I went to sleep it started not syncing and had a restarting fit... I woke up to the watch on 63%..
I have been onto the live chat multiple times (who have tried to be helpful to be fair to them). They referred me onto their "versa specialist". I got an email telling me to try setting it up as a new device again (which I had already done several times). I have responded with multiple updates about the devices behaviour to try and see if it is a software issue (which an update could fix) or a hardware issue. After 2 days they replied asking me to send the device back to them.. However it has to be sent by courier as the postal service wont take devices with batteries.. And the quotes I have been getting have been about €80 for delivery to them... so I am contacting again to try sort an alternative.. They dont seem to agree that it is a common issue... But I agree with you that there are multiple different threads with similar issues! Some clarity on the actual cause of the issue would really be appreciated! Particularly as I have never had a negative issue with Fitbit before.. My whole family have had multiple trackers, the zip, flex, charge 2, alta, aria 2.. and never had major issues (besides the occasional band breaking) until the Versa!
07-06-2018 04:55
07-06-2018 04:55
Thought it only appropriate to update after contacting them again. And also it is good to comment on good things as well as bad! After a quick chat with one of the support staff on the online chat, the case has been escalated to the European team who will provide me with a shipping label so I will not have to pay shipping costs! So now we wait to see whether the replacement solves the issues!
Best Answer07-08-2018 11:42
07-08-2018 11:42
Best Answer07-08-2018 13:34
07-08-2018 13:34
I bought a Versa 4 days ago. Took forever but eventually got it set up and synced and things were good... For less than 24 hrs. I have had nothing but problems since then.
I get push notifications saying it synced, but then go to the app and it says it have synced since the day before. Tried everything. Notice that the app says to set up wifi, despite having done so during set up and it working fine for awhile.
I have both turned off the Versa and restrarted. Uninstalled/reinstalled the app. Restarted Bluetooth time of times. I even tried getting resetting the Versa and starting all over. After this it worked for about 5 minutes then no Wifi, won't connect to Bluetooth.
When I contacted support, they said my phone is not a supported device, so they can't help me.
I have also tried using a Windows 10 laptop, it worked long enough for one sync and music transfer and then it won't send or connect with that either.
Should I just return the Versa? Anything else anyone thinks might help? I am so freshest, surrending hours a day trying to get this to consistently work.
Best Answer07-08-2018 13:44
07-08-2018 13:44
I was almost at the point if no return but i found the shutdown section on my Blaze and shut it completely down, restarted and then set up as a new device on my iphone and now its working again. problem is, i guess, why did it disconnect in the first place?
Best Answer07-10-2018 04:59
07-10-2018 04:59
Same here. I've had my beautiful special edition Versa for a week now. At first it synced perfectly. It stopped syncing two days ago, and then it only captured 1/2 days activity, though the entire day was on the device. Now it won't sync at all. I am going to lose yesterday and this mornings exercise by disconnecting and reconnecting via "remove this device" and reinstalling. It's a shame that such a nice tracker, is proving useless.
Best Answer07-25-2018 12:29
07-25-2018 12:29
Another update... not so good this time. So I returned the Versa SE as instructed and I got confirmation of delivery last Monday. On Friday I got an email saying the replacement Versa (not the SE) was issued. I got back on again to try sort it out before the incorrect device was posted to me. To be fair the agent I was speaking to was helpful (after a small argument where I had to convince him they were different) and after sending on a picture of my receipt (and the box) they issued the correct replacement. However having not received any details of shipment by today I contacted (again) to be told that apparently the order was stuck (they couldnt say why) and they have contacted the Shipping team to try sort it out now.... So now waiting on another email to see what is going on.
Best Answer07-26-2018 16:14
07-26-2018 16:14
I am currently having the same issue I purchased the Fitbit in April but for the past 2 or 3 weeks its been hell! I too am linking it to a LG G6. Has anyone had any update on what is the issue?
