06-26-2022 02:27
06-26-2022 02:27
I've only been using my versa for 6months. Few days ago I noticed the battery draining quite fast. Today the time would not sync. I can't seem to update it using WiFi or Bluetooth. What's the problem??
06-26-2022 05:27
06-26-2022 05:27
Hi @MittaKaren - it is probably the moment to restart both the watch and phone, to make sure they are working optimally. The sync is done via Bluetooth generally and after a restart and sync it should set the time, unless there was a time zone change when a different process is needed sometimes.
Best Answer06-26-2022 15:47
06-26-2022 15:47
Best Answer06-27-2022 01:32
06-27-2022 01:32
@MittaKaren- see How do I restart my Fitbit device?
You can also use Shutdown from the watch Settings, About menu. Wait at least 10 seconds [to allow it to complete] before placing it on charge to restart it and charge it. If it's already charged just push the button for a second and wait.
Best Answer06-27-2022 02:27
06-27-2022 02:27
Best Answer06-27-2022 02:35
06-27-2022 02:35
@MittaKaren - you can't pair the watch in Bluetooth, it is done via the Fitbit App.
It is possible the watch is faulty but unusual for Bluetooth to stop.
If you have Versa in your phone's Bluetooth remove it.
Logout of the app and login. It should make a pair and link.
If not , click on " Set up a Device " and replace it, this will attempt to find the Versa more aggressively.
06-27-2022 08:31
06-27-2022 08:31
Best Answer06-27-2022 09:29
06-27-2022 09:29
@MittaKaren - it might need more drastic treatment to fix, chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
Best Answer06-28-2022 09:39
06-28-2022 09:39
My time is off 1 hour. I did travel to a different time zone. It changed when I got to the other time zone but will not switch back.
What is the process to fix this?
Best Answer06-28-2022 09:45
06-28-2022 09:45
Hi @antiquetrapjr - In the Fitbit App, click profile photo, App Settings, turn off automatic time zone and location and set the time zone manually and then sync.
Afterwards you can set the settings back as they were.
Best Answer06-28-2022 10:59
06-28-2022 10:59
Best Answer06-28-2022 11:51
06-28-2022 11:51
