09-02-2019
17:00
08:36
JuanJoFitbit
09-02-2019
17:00
08:36
JuanJoFitbit
I am extremely upset with my Versa. Heartbeat completely inaccurate (too high) which gives me way too many calories burned. Can't accurately judge calories in/out. Worked great for 3 months, now this! Have cleaned it, reset it, cleared both app and Versa and reinstalled app and initiated Versa again from scratch. Still screwed up. Showing 104 beats right now while I'm sitting here watching tv. Best present I ever got has turned into a huge disappointment!
09-02-2019 17:06
09-05-2019 12:11
09-05-2019 12:11
@GilMil it's great to see you in our Fitbit Community. By the way, I'm sorry for the late response. I'm also sorry to hear that your Versa has been tracking high heart rate issues even though you have troubleshooted this issue properly before contacting our forums. I totally understand how frustrating this is for you.
I'd like you to try one more workaround that has been helpful for this type of issues which consists in performing a factory reset. To do so on your device, open the Settings app > About > Factory Reset or Clear User Data. Please sync your watch before this in order to avoid losing current data.
Finally, make sure of the following details:
Thank you for helping us to keep the Community organized @USAF-Larry.
I'll be around if any question arises.
09-05-2019 14:27
09-05-2019 14:27
Best Answer09-05-2019 16:40
09-05-2019 16:40
Hi, I would suggest to contact Customer Support about your problem. Regards kuzibri
09-07-2019 08:35
09-07-2019 08:35
@GilMil I'm sorry for the late response. However, regarding the issues that your Versa experienced, I was able to get in touch with our Support team and was told that you contacted them via phone as advised @SunsetRunner. I'm so glad to hear that a solution was provided and you will be back on track soon.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! 😀
09-07-2019 08:45
09-07-2019 08:45
Mine is showing a HR of 176 while sitting quietly. Very frustrating! I have restarted it at least 10 times. It works for a little while and then jumps back up. This started about 4 days ago.
Best Answer09-09-2019 09:36
09-09-2019 09:36
@Bassbird thank you for joining us in this thread and our Fitbit Community. By the way, I'm sorry for the late response.
Since your Versa is still tracking high rate readings after your restarted it, I'd like you to try a factory reset. To do so on your device, open the Settings app > About > Factory Reset or Clear User Data. Please sync your watch before this in order to avoid losing current data. After this, make sure of the following details:
After this, monitor your heart rate during the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome! 😀
03:03
07:16
JuanJoFitbit
09-13-2019
03:03
07:16
JuanJoFitbit
Thank you for your reply. I've tried restarting multiple times, I also reset to factory default, all with not much luck. Now it has registered my sleep for a week because of the erratic HR readings. It will get "stuck" at a rate and stay for hours until I reset it. Now the HR monitor will not stay on consistently. I'm getting pretty frustrated as the data is almost completely inaccurate for the day.
Same here. Now no HR and the battery drains in hours.
Moderator edit: merged reply
Best Answer09-16-2019 07:19
09-16-2019 07:19
@Bassbird I'm sorry for the late response. However, I appreciate your reply and time spent trying the recommended troubleshooting steps.
Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions! 😀
