12-17-2018
19:57
08:31
HeydyF
12-17-2018
19:57
08:31
HeydyF
I am not sure what happened to my watch. I got it about a couple of weeks ago and ever since then it has been fine. Today it was syncing and I guess something went wrong. Ever since then my fitbit keeps turning off and on and I don't know how to stop it from doing that. Please can anyone help me?
Best Answer12-17-2018 20:35
12-17-2018 20:35
@iluvpink962 WHat's your phone model and OS?
You can try this for now:
12-17-2018 20:21
12-17-2018 20:21
@iluvpink962 Try rebooting your tracker several times by pressing and holding the left and bottom right buttons until Fitbit logo flashes.
12-17-2018 20:33
12-17-2018 20:33
It wasn't syncing as well so I decided to shut it down. Now that I turned it back on it doesn't want to sync with my phone anymore
12-17-2018 20:35
12-17-2018 21:26
12-17-2018 21:26
Thank you. I am doing this right now and hopefully it works. BTW I have a Galaxy note 8
Best Answer12-18-2018 00:50
12-18-2018 00:50
Well I guess I was just being hopeful. It didn't work and I am not sure what to do anymore or why now it started to do this
Best Answer12-18-2018 13:04
12-18-2018 13:04
@iluvpink962 Is it still turning ON/OFF? Or is it simply not syncing?
12-19-2018 10:31
12-19-2018 10:31
Hey @iluvpink962, I hope you are doin' fine! As @Marrrmaduke said, what is the issue that you still having with your Versa, is the display not working or still not syncing? If your watch still not syncing, I'd like you to take a look at all the troubleshooting in this help article: Why won't my Fitbit device sync? However, if it is the display that still not turning on, I'd like you to restart it.
Let me know how it goes!
12-19-2018 10:36
12-19-2018 10:36
I have tried all from the troubleshoot. Nothing is working so I finally gave up
Best Answer12-20-2018 01:24
12-20-2018 01:24
@iluvpink962 have you tried restoring Versa to factory defaults?
12-22-2018 08:34
12-22-2018 08:34
Hey @iluvpink962, how did your Versa go? Is it working fine now? By any chance, did you try to factory reset it as @Marrrmaduke suggested? If you haven't, you can try that out, but keep in mind that all of the information on the watch will be erased, so please sync it prior doing that and remember that you'll have to install all the apps again through the Fitbit app.
