12-03-2018
14:38
08:17
MarcoGFitbit
12-03-2018
14:38
08:17
MarcoGFitbit
Please help! I have tried all advice from other users in other posts. Still not working!
12-03-2018 19:06
12-03-2018 19:06
hello emmybiz04, how are you doing? sorry for the problem you're facing,have you tried making sure your app on your smart phone is up-to-date ,you might want to first make sure your phone's app is updated first
Best Answer12-03-2018 20:18
12-03-2018 20:18
@emmybiz04 Can you please elaborate? Are you getting any error messages? Which step are you stuck at?
Best Answer12-04-2018 08:22
12-04-2018 08:22
Hello @emmybiz04, have a warm welcome to the Fitbit Community. It's nice to see you too @james58 and @Marrrmaduke, thanks for your input about this situation. ![]()
@emmybiz04, I appreciate your participation in the Forums and for sharing your experience with us. As @james58 and @Marrrmaduke mentioned, would it be possible for you to reply to us with more information and details about your issue? This will be very helpful for us to check this further.
In the meantime, please try the following. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
