Versa watch display is very dim
The face on my Fitbit Versa is suddenly dim and difficult to see.  The watch is charged.
2 REPLIES 2
Hello @SBess
I moved your post to the Versa product help forums where you're more likely to get help with your issue.
Hi @SBess - is it possible that your watch is in sleep mode? This automatically dims the display.
To check, go to Quick Settings, this can be long press if the action is not reassigned.
If not go to watch Settings, there adjust the brightness (you must remove Sleep mode from Quiet modes first).
If necessary sync the watch and restart it using the buttons.
Thanks @RiekoC  for moving to the correct forum.
