06-19-2018 09:49
06-19-2018 09:49
I’ve been using my versa for a couple of weeks and have noticed that I can’t get the weather to update unless I sync with the Fitbit app.
Im using an iPhone and have location services on, cellular data on and am not sure what else to do.
06-19-2018 10:29
06-19-2018 10:29
That is correct. The only way your tracker can update the weather app is to sync with the Fitbit App.
06-19-2018 13:17
06-19-2018 13:17
Oh, that’s a bummer. I had a clock face that showed the weather it’s a little pointless if I can’t take a quick glance at it and see a weather update. ☹️
06-19-2018 14:41
06-19-2018 14:41
Having the same problem. I sync mine in the morning when I get up. I don't get the weather at all.
I have tried all the same things you mentioned. Also using iphone, with everything turned on.
I am also having a problem with charging. It takes hours. It said 95% for over an hour.
Is that normal? I am absolutely nuts trying to get anything beyond paying for a membership on Deezer. Can't get it to work or to move music to it no matter what I try.
I had a Charge HR 2 for a couple of years and loved it. I was really looking forward to Versa but questioning if it was worth spending the money for.
