12-18-2018
06:44
04:25
YojanaFitbit
12-18-2018
06:44
04:25
YojanaFitbit
Updated Versa, when I swipe up on clock face nothing happens. I have done a hard reset several times, even tried unpairing...this is so frustrating. Last week it wouldn't sync at all...finally got that to work...just when you have one issue resolved there is another..
12-18-2018 09:02
12-18-2018 09:02
I was using business, not stats... however I just tried every Fitbit clock face. I can see my stats using the simple clock face.
I don't like the format, but at least it's working for now. Thank you for all your help! Happy Holidays and Happy New Year!
Best Answer12-18-2018 06:53
12-18-2018 06:53
Hi, are you using a third party Clock Face?
Best Answer12-18-2018 06:57
12-18-2018 06:57
Best Answer12-18-2018 06:59
12-18-2018 06:59
Hi..the clock face I'm using came from the Fitbit app.
Best Answer12-18-2018 07:01
12-18-2018 07:01
Is this clock face by Fitbit itself or one out of the column "all clocks". What is the name of your Clock Face? You can find this by going to and pressing Clock Faces. On the left side you will see "My Clock".
12-18-2018 07:06
12-18-2018 07:06
Dark side
Best Answer12-18-2018 07:21 - edited 12-18-2018 07:26
Hi, I looked up the Clock and it's a third party clock. If I were you, I would contact the developer of this clock. Go to Clock Faces - All Clocks - type in the search field Dark side and you will get the clock including information about the developer. Click contact the developer and send him an email with your problems.
Another possibility is that this clock face is not compatible with the new Fitbit iOS version.
In the mean time, I would advice you also to install one of Fitbit's own clock faces (whether you like them or not
) to see whether this solves your stats problems. Good luck.
12-18-2018 07:26
12-18-2018 07:26
Does this seem to be an issue with the update?
Best Answer12-18-2018 07:30
12-18-2018 07:30
Might be, cause the newest version (.30) completely differs from the one we used to use untill now (.19).
Best Answer12-18-2018 07:49
12-18-2018 07:49
I changed the clock face to a Fitbit one, I am still unable to get any stats on my versa when I swipe up.
Best Answer12-18-2018 07:56
12-18-2018 07:56
I would advice you to contact Customer Service about this issue: https://help.fitbit.com/?l=en_US&c=Topics%3ATroubleshooting and ask them about clocks an version .30. Strange that a clock face from Fitbit itself has the same issues. For certainty: what is the name of the clock?
Best Answer12-18-2018 08:06
12-18-2018 08:06
Mine is doing the same thing. I have a fitbit clockface.
Best Answer12-18-2018 08:08
12-18-2018 08:08
What's the name of your clock?
Best Answer12-18-2018 08:09
12-18-2018 08:09
I am using the stats clock face
Best Answer12-18-2018 08:11
12-18-2018 08:11
And you also updated to the latest version of Fitbit iOS?
Best Answer12-18-2018 08:12
12-18-2018 08:12
Yep. That is when it stopped working. I tried re-starting the watch 3x, and took the phone in and out of airplane mode a couple of times.
12-18-2018 08:17 - edited 12-18-2018 08:19
It's hardly believable that Fitbit relases a new version in which Clock Faces are not working properly anymore, but since you're not the only one with this problem, it must be concluded that it's true. BTW, did you receive within your Fitbit app that a new release was available for your Versa? Just one, maybe strange, question: when you swipe from right to left, do you see Today there??
Best Answer12-18-2018 08:19
12-18-2018 08:19
Yes. That functionality seems to be intact. And when I swipe down I can still see my updates, but I can't get into the stats by swiping down. Its a bummer 😞
Best Answer12-18-2018 08:23
12-18-2018 08:23
When I swipe right or left I get my apps..exercise, music, etc...
Best Answer12-18-2018 08:24
12-18-2018 08:24
Two things:
1. did you receive within your Fitbit app that a new release was available for your Versa?
2. what I meant when asking to swipe from right to left: is there a Today app visible, stated otherwis: has Today become a seperate app in the new version or not?
