11-20-2018 11:31
11-20-2018 11:31
I've been trying to connect my Versa to Wi-Fi but it keeps saying connection out of range. I am able to connect other devices but not the Verse. As simple as it seems, it will not connect. Not sure what else to try. I need to download the firmware in order to use it so at this point I'm ready to return it. Any suggestions?
Thanks!
Best Answer11-20-2018 13:31
11-20-2018 13:31
Is your wifi supported?
"Versa can connect to open, WEP, WPA personal, and WPA2 personal Wi-Fi networks. Your watch won't connect to 5GHz, WPA enterprise, or public Wi-Fi networks that require logins, subscriptions, or profiles. If you see fields for a username or domain when connecting to the Wi-Fi network on a computer, the network isn't supported."
Best Answer11-20-2018 19:16
11-20-2018 19:16
Best Answer11-20-2018 20:46
11-20-2018 20:46
@GIEAN try inputting the network manually in the fitbit mobile app. also you can update versa via bluetooth. it will just take an hour or two.
06:42
08:23
11-21-2018
06:42
08:23
It's great to welcome you @GIEAN, @SunsetRunner and @Marrrmaduke thanks for the input.
I appreciate all the efforts in trying to fix this issue and recommend taking a look at the help article Why won't my Fitbit watch connect to Wi-Fi? and follow the instructions provide there.
I hope this helps, let me know the outcome. ![]()
11-21-2018 19:00 - edited 11-21-2018 19:15
This is the best answer.
I didn’t know how to connect my watch to my home Wi-Fi because I didn’t read the instructions in the help. When I went to Why won't my Fitbit watch connect to Wi-Fi? and read the instructions, within few minutes my network name showed up and when I clicked on it, I was asked for the network password. After entering the PW, I was fully connected with the router IP address.
Thanks for the Moderator!
Best Answer11-23-2018 13:19
11-23-2018 13:19
Best Answer11-23-2018 13:22
11-23-2018 13:22
Yes I even tried that but it didnt help. So I returned it for a full refund. There was something definitely wrong with the one I received.
