09-23-2019
14:16
05:06
JuanJoFitbit
09-23-2019
14:16
05:06
JuanJoFitbit
I went to charge my versa which was completely dead. When I took it off the charger it seemed to work but kept resetting itself and couldn't use the screen to check my steps. Then about hour later screen went complety dark. In the morning I notice condensation under the sensors. What can I do?
09-24-2019 05:05
09-24-2019 05:05
@Capgirl21 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't turn on completely after charging it.
Please restart your Versa manually as described in this help article. After this, charge it for 2-3 hours and see if it vibrates and turns on. Finally, try changing the clock face to one developed by Fitbit, not a third party clock face and see if the issue gets fixed.
Keep me posted on the outcome! 😀
Best Answer09-25-2019 06:57
09-25-2019 06:57
Best Answer09-25-2019 07:07
09-25-2019 07:07
Same issue. This morning my versa was dead, so I charged it and within 15min it was dead again (would not turn on). I put it on charger and it showed full but will not power up. When I take it off charger it goes black again.
Best Answer09-25-2019 07:49
09-25-2019 07:49
I also have the same issue. Versa died on me yesterday, put it on the charger overnight. Showed at 100% this morning and now 3 hours later is dead and the app cannot find it.
Best Answer09-25-2019 08:39
09-25-2019 08:39
I managed to get to factory reset while it was on the charger. Reset it. Repaired with app. Reinstalled updates (took an hour). Battery charged to 100% according to app and versa display. 5min after taking it off charger, screen is black and won't power on. Guess it's dead.
