My wife's versa was working slowly after the latest update and froze with the fitbit logo on the screen. It was left on the charger all night, but will no longer turn on.
I have tried using another charger. I have tried resetting it, nothing happens. I have tried plugging it into a computer, nothing happens.
I gotta say, it is pretty exciting to deal with this issue right before Christmas, when it was an early gift for my wife...
Best AnswerThe update never completed, but I am pretty sure it was through BT. The phone now shows that the Versa needs to update, but it will not connect, as the device will not turn on.
Nothing happens when the Versa is plugged in to the charger or connected to a PC. I have tried on two different chargers and both chargers are working fine with my Versa (Not the broken one).
Best AnswerHi, did you do a factory reset, by pressing and holding all three buttons untill you feel a strong vibration and after hearing this release the lower right button? sometimes you'll have to repeat this procedure more than once. If you already did that and nothing happened, then I would advice you to contact Customer Support: https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs . Good luck and, depite your Versa problems, Happy Holidays.
Best AnswerMy Versa is doing the exact same thing! It’s very frustrating since my too was an early Christmas present.
Best AnswerYeah, holding the buttons does nothing. I will contact costumer support.
Best AnswerI cannot speak for your dealings with costumer support, but my contact with then went smoothly. It helps that we are still within the warranty time, which I believe is 45 days from purchase.
After about 30 minutes from contacting costumer support, we had a new device being sent to us. Hopefully this one does not have the same problem.
